7941 SCCP 8.5(2) Firmware
chuencheat
Does anyone still have the firmware file for Cisco 7941 SCCP version 8.5(2)?
cmterm-7941-7961-sccp.8-5-2
Appreciate if you can share the file here.
Thank you.
Check google, there are  many places where u find the old files.
Response Signature
Unfortunately the links from cisco.com do not work. See below. Any other way to retrieve the file would benefit some Signal Army units.
Site: https://www.cisco.com/web/software/282074289/26638/cmterm-7941_7961-sccp.8-5-2-readme.html
Link to table for file download (Error 404) https://www.cisco.com/cgi-bin/tablebuild.pl/ip-7900ser
Products that reach their EOL/EOS are removed from the downloads area at cisco.com, that's why any download link you find won't work anymore.
Aside from searching the internet you can reach out to your Cisco SE as a best effort
java
if this helps, please rate
