Participant
7942 Phone not registering on SRST CME
I have setup the following cluster:
CUCM 7.1.5
Cisco 3925 with (C3900-UNIVERSALK9-M), Version 15.2(3)T and uck9 technology for SRST
I have setup the SRST under CUCM to point to router aswell as added that SRST service under the device pool of the 7942 IP Phone.
When I turn off the CallManager services on both Pub and Sub, my 7942 tries to registers but is not getting anywhere.
Here is my CME config
ip dhcp pool 123_VOICE
network 10.Y.Y.0 255.255.255.0
default-router 10.Y.Y.254
option 150 ip 10.Y.Y.1
interface GigabitEthernet0/1.900
description VOICE NETWORK
encapsulation dot1Q 900
ip address 10.Y.Y.254 255.255.255.0 secondary
ip address 10.Y.Y.5 255.255.255.0
ip flow ingress
ip flow egress
ip virtual-reassembly in
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.Y.Y.5
interface GigabitEthernet0/2
description WAN
ip address X.X.X.X 255.255.255.252
telephony-service
srst mode auto-provision none
srst dn template 1
srst dn line-mode dual
max-ephones 265
max-dn 600
ip source-address 10.Y.Y.1 port 2000
time-zone 41
date-format dd-mm-yy
dialplan-pattern 1 00000000 extension-length 8 extension-pattern 11111111
voicemail 11111111
max-conferences 8 gain -6
transfer-system full-consult
secondary-dialtone 9
The phone is using phone load SCCP42.9-1-1SR1S.
Help!
Everyone's tags (5)
1 ACCEPTED SOLUTION
Highlighted
VIP Advisor
The IP configured in CME for telephony-service and TFTP isn't correct (10.Y.Y.1). Your router Gi0/1.900 is having IP 10.Y.Y.5.
Correct this and try.
4 REPLIES 4
Highlighted
VIP Advisor
Highlighted
Participant
Thanks.
Its working now. Sorry, first time using SRST and CME.
Highlighted
VIP Advisor
Don't be sorry mate ... This how we learn
Highlighted
hey guys i have a similar issue with following setup:
CUCM 8.6.2
Cisco 2901, Version 15.2(1)T with  uck9 technology for CME-SRST.
The Configuration was all correct in 2901 CME-SRST router as wee as CUCM.8.6. My IP Phone settings were also correct one.
But the problem was that, my 7942 series IP Phones only can't show required template on IP Phone screen in SRST Fallback mode. Only the SRST fallback message displays. My 7940 & 7962 series IP Phones were working fine.
The IP Phone was having IOS version SCCP42.9-2-1S, i have DOWNGRADE IT TO  8.3.3 version.
After which the phone reflects the template and the DN.
