7942G resetting to Factory defaults
balaji11p80
I have got an cisco 7942G through my work for home use. the support contract expired sometime in 2013. I am trying to reset factory default and it stuck in the "UPGRADING" screen and nothing happens after that. Any help to resolve this is greatly appreciated.
3 Accepted Solutions
Terry Cheema
Do you have a call control CUCM/CME? Is the phone able to talk to the TFTP server? It needs to download the load files from TFTP - before it is in usable state, since you have performed a factory reset.
Phone needs to talk to a TFTP server either your call control or You can set this up on a PC as well (Refer here or google for better instructions)
-Terry
Please rate all helpful posts
Look up on this blog or the URL I provided in previous post or google (recover bricked cisco phone)
You need tftp and you need to download and install the files in root directory. Also set the option 150 ip as your PC.
-Terry
Look at it if it has DHCP Options setting somewhere (though I doubt it). Do you have access to any basic Cisco switch use that? Otherwise it appears easier option is take it back to work and plug it in and it will download all files etc. and will be fine.
-Terry
7 Replies 7
Terry Cheema
-Terry
I dont have the call control. This is now connected to my home network. DHCP is being provided from my Router. I have downloaded the TFTP server on my laptop. What should i do next to bring back the phone live.
-Terry
completed all the above. Now trying to see how i can set the option 150 ip as my PC. I am using a Netgear SOHO router for my DHCP.
-Terry
Apple to crack this by setting up a dhcp server with option 150 and boom it worked. Thanks.
Good stuff - Thx for the feedback!
-Terry
