7965 Display Error - Port Configuration Error
Jason Lee
Community,
I have a customer who is experiencing what appears to be a cosmetic error on their 7965s.  When deploying endpoints into the field they have found that if they hard code the speed/duplex to 100/Full on the PC port of the phone they get a "Port Configuration Error".  The funny thing is that the PC appears to function normally at 100 Full.  When I change the endpoint to auto-negotiate from CUCM the error goes away.
Has anyone ever run into this?
Endpoint:     7965
Protocol:     SIP
Load:          SIP45.9-3-1SR2-1S
tonyperla
What is the switch port set to?
Please rate helpful posts
Tony
I'm not sure.  The guys working on the network portion of the install have departed.  The issue I'm running into is on the PC port of the phone connected to a daisy-chained PC.
No worries, how about the actual switch port on the phone?  Are both the PC and SW ports set to Auto or 100 Full?  I would still be curious about what the network port on the switch is set to as well.  I am running 7965G's in both SCCP and SIP form and no matter how I have the ports set and cannot recreate.  I am also running 9.3.1sr2 firmware on both.
Tony
