11-14-2006 06:09 AM - edited 03-14-2019 06:47 PM
i make background images for 7985 Video(firmware of 7985 is 4.1.2) phone but when i select one of the listed image the error message indicating this image is not supported protocole. i check configuration as followin:
1. make image with 800x600 PNG file
2.put the prevouise image 80x600x16
3.edit List.xml file as
<ImageItemImage="TFTPPath:Desktops/800x600x16/logo7985.png"
URL="TFTPPath:Desktops/800x600x16/logo7985.png"/>
4.after that image is listed but whn i select it the error messege appear unsupported protocole.
thanx alot
11-14-2006 07:33 AM
Hi Hani,
Have a look at this good doc for the 7985;
It looks like the List.xml should look like this;
URL="TFTP:Desktops/800x600x16/logo7985.png"/>
with a space between ImageItem and Image and with just TFTP rather than TFTPPath.
Hope this helps!
Rob
Please remember to rate helpful posts.....
11-14-2006 11:44 PM
Dear Rob
thank you vey much its working and everything is fine .
Kind Regards.
