802.1x in Database Schema
Gordon Ross
Level 9
Level 9
Where is the "802.1x Authentication" (and other Product Specific) parameters for a device defined in the database schema? It's not in the main Device table. I'm guessing it's in some linked table, but I can't work out which.
GTG
PS - I did think about posting in the developer forums, but as no-one answers questions there....
Please rate all helpful posts.
Hi Gordon.
This could be a useful link
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/datadict/8_5_1/datadictionary_851.pdf
Carlo
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
I already have the data dictionary and it's not listed in there.
I've found that by doing an export of phones, 802.1x gets mentioned in a field with the name "XML", but I don't know which database table/column this XML is actually in. It's certainly not part of the device table.
