880 Voice Gateway no outside lines
spurs2k18
Have run into a problem that have been struggling with.  Recently a few locations have switched over to Meraki (Mx and MS) from a 2801.  Before they were connecting via ATA adapters for the cordless phones, but now with the upgrade, these shouldnt be needed anymore.  Anyhow, when you dial into location, line rings once, or twice, and than turns to a busy signal.  Currently on CUCM 9.1.2.  Below is the config from the 880 VGW.
no service pad
no banner exec
no banner login
hostname 227-VG
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
network-clock-participate wic 0
no ip domain lookup
ip domain name twig.local
ip cef
no ipv6 cef
voice-card 0
username admin privilege 15 password xxxxxxxxx
enable password xxxxxxxx
interface BRI1
no ip address
interface BRI2
no ip address
shutdown
interface FastEthernet0
no ip address
shut
interface FastEthernet1
no ip address
shut
interface FastEthernet2
no ip address
shut
interface FastEthernet3
no ip address
shut
interface FastEthernet4
ip address 172.18.127.253 255.255.255.0
no shut
duplex auto
speed auto
interface Vlan1
description $ETH_LAN$
no ip address
ip tcp adjust-mss 1452
shutdown
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route 0.0.0.0 0.0.0.0 172.18.127.254
cdp run
control-plane
voice-port 1
no comfort-noise
voice-port 2
no comfort-noise
voice-port 3
no comfort-noise
description FXS to Store Phone
voice-port 4
voice-port 5
voice-port 6
voice-port 7
no comfort-noise
timing hookflash-out 50
timing guard-out 1000
connection plar 7227
description 956xxxxxxx
ccm-manager fallback-mgcp
ccm-manager redundant-host 192.168.3.32
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 192.168.3.33 192.168.3.32
ccm-manager config
mgcp
mgcp call-agent 192.168.3.33 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
mgcp default-package mt-package
no mgcp package-capability res-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 ecm
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface FastEthernet4
mgcp bind media source-interface FastEthernet4
mgcp profile default
dial-peer voice 999010 pots
service mgcpapp
port 3
dial-peer voice 999011 pots
service mgcpapp
port 7
call-manager-fallback
secondary-dialtone 9
max-conferences 0 gain -6
transfer-system full-consult
ip source-address 172.18.127.253 port 2000
max-ephones 5
max-dn 5
default-destination 7227
voicemail 96xxxxxx
What is the output of
show mgcp endpoints
show mgcp connection (during the call)
show ccm-manager
Also, during call setup share the output of debug mgcp packet
aaln/S0/SU1/0@LPZ227-VG
aaln/S0/SU3/0@LPZ227-VG
LPZ227-VG#show mgcp connection
LPZ227-VG#sh ccm-man
LPZ227-VG#sh ccm-manager
MGCP Domain Name: LPZ227-VG.twig.local
Priority Status Host
Primary Registering with CM 192.168.3.33
First Backup Backup Ready 192.168.3.32
Second Backup None
Current active Call Manager: None
Backhaul/Redundant link port: 2428
Failover Interval: 30 seconds
Keepalive Interval: 15 seconds
Last keepalive sent: 19:35:21 UTC Jul 20 2018 (elapsed time: 2w4d)
Last MGCP traffic time: 13:40:53 UTC Aug 8 2018 (elapsed time: 00:00:00)
Last failover time: 13:40:23 UTC Aug 8 2018 from (192.168.3.33)
Last switchback time: 13:40:53 UTC Aug 8 2018 from (192.168.3.32)
Switchback mode: Graceful
MGCP Fallback mode: Enabled/ON
Last MGCP Fallback start time: 09:36:02 UTC Aug 1 2018
Last MGCP Fallback end time: None
MGCP Download Tones: Disabled
TFTP retry count to shut Ports: 2
FAX mode: disable
Configuration Error History:
Can you share the debugs and show mgcp conn
Sorry for late reply. got little swamped. mgcp is showing nothing. As for debugs, which one do i need to run?
