02-04-2016 01:10 PM - edited 03-17-2019 05:45 AM
Does anyone know how I change the expansion module mode from 2 columns to 1 column on an 8800 expansion module?
Ciscos documentation on the configuration is poor / non-existant
Thanks in advance
Solved! Go to Solution.
02-04-2016 02:20 PM
You can set it from phone settings-->applications
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cuipph/8800-series/english/userguide/P881_BK_CC6C5F2C_00_cisco-ip-phone-8800_series/P881_BK_CC6C5F2C_00_cisco-ip-phone-8811-8841_chapter_01000.html#P881_TK_CF1AB5BE_00
regards,
-Do rate helpful posts
02-04-2016 01:49 PM
there is a parameter in phone configuration page "One Column Display for KEM" enable it to get one column display.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cuipph/8811_8841_8851_8861/10_5/english/adminguide/P881_BK_C0632068_00_cisco-ip-phone-8811-8841/cisco_ip_phone_key_expansion_module.pdf
regards,
02-04-2016 02:10 PM
Thank you! Super helpful.
One other question......ever since we went to the new firmware the font is bigger. Is there a way to adjust the font size on the phones?
02-04-2016 02:20 PM
regards,
02-04-2016 02:28 PM
Extremely helpful.
Really appreciate it, thanks
