10-23-2017 05:28 AM - edited 03-17-2019 11:27 AM
What do the icons mean on the 8800 expansion module?
When you look at the picture for example there is a colored bubble with a number in it next to a line.
10-23-2017 06:10 AM
The data sheet has explanations of each icon/color:
10-23-2017 06:15 AM - edited 10-23-2017 06:16 AM
I have seen that document and fail to see where is states what the number means in the bubble.
10-23-2017 06:16 AM
Can you post picture of what you are seeing?
What color is the bubble? Normally it would show missed calls/voicemail messages count.
10-23-2017 06:27 AM
Sure thing
10-23-2017 06:43 AM
The blue icon identified if the button is associated with Line, Speed Dial, BLF, service, etc. and if it is a Line then it shows status, i.e. on hook, off hook, etc.
The red count tells you how many missed calls/voicemail messages are on that line.
The Yellow/Green/etc next to a BLF shows that monitored line status, i.e. available, on call, etc.
10-23-2017 06:45 AM
10-23-2017 07:07 AM
I looked through the 88XX user guide and it does cover some of it, but not all. I would be your best reference AFAIK.
