8831 Linked Mode status always primary upgrading?
samhopealpha
Level 2
Level 2
Hi Everybody,
We have 2 x 8831 and both station are linked together via DCU
Firmware: 8831 10.3(1)SR1
Everything are working fine,
except the phone settings > status
Linked Mode: primary upgarding
Is it normal? because the phone firmware is already shown 10.3(1)SR1
Sam
vince.castro
Hi Sam,
Yes this is normal.  If the Secondary unit is not on the same sw/firmware as the Primary unit.  The Primary unit will initialize an upgrade to the Secondary.  It may work the same with the Secondary having a newer firmware as well, and forcing an upgrade to the Primary.  On the keypad display you will see a brief pop up window stating the upgrade is happening and not to unplug the unit, and on the firmware details under Apps menu that is where you will see the "upgrading progress".
vince.castro
Hi Sam,
