Hi, I have a problem with the Cisco 8831 phone. The phone does not register to the PBX network. The supplied sip packets do not contain authorization fields, which means that the phone is not registered in the network. Of course, I made the complete configuration. Logs downloaded from the PBX server for Cisco 8831 look like this:
REGISTER sip:192.168.1.250 SIP/2.0
Via: SIP/2.0/UDP 192.168.1.109:5060;branch=z9hG4bK5ba61c6b
From: <sip:25@192.168.1.250>;tag=ac44f2117d92000438e3696a-3602c842
To: <sip:25@192.168.1.250>
Call-ID: ac44f211-7d920004-2554b732-65f62476@192.168.1.109
Max-Forwards: 70
Date: Sat, 01 Jan 2000 00:12:55 GMT
CSeq: 103 REGISTER
User-Agent: Cisco-CP8831G/10.3.1
Contact: <sip:25@192.168.1.109:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-ac44f2117d92>";+u.sip!devicename.ccm.cisco.com="SEPAC44F2117D92";+u.sip!model.ccm.cisco.com="659"
Supported: replaces,join,sdp-anat,norefersub,extended-refer,X-cisco-callinfo,X-cisco-serviceuri,X-cisco-escapecodes,X-cisco-service-control,X-cisco-srtp-fallback,X-cisco-monrec,X-cisco-config,X-cisco-sis-5.2.0,X-cisco-xsi-8.5.1
Content-Length: 0
Comparing to Cisco 8865 phone which successfully register into the network
Via: SIP/2.0/UDP 192.168.1.122:5060;branch=z9hG4bK1e07819c
From: <sip:26@192.168.1.250>;tag=c4b36aba9b01000824b86862-2d1a9ade
To: <sip:26@192.168.1.250>
Call-ID: c4b36aba-9b010002-5bd2a904-6ce24d6a@192.168.1.122
Max-Forwards: 70
Session-ID: 6614c4ed00105000a000c4b36aba9b01;remote=00000000000000000000000000000000
Date: Fri, 10 Jul 2020 18:05:04 GMT
CSeq: 106 REGISTER
User-Agent: Cisco-CP8865/12.1.1
Contact: <sip:26@192.168.1.122:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-c4b36aba9b01>";+u.sip!devicename.ccm.cisco.com="SEPC4B36ABA9B01";+u.sip!model.ccm.cisco.com="36225";video
Authorization: Digest username="26",realm="platan.proxima",uri="sip:192.168.1.250",response="6e9f4ab0c4e799ebe9dfe407331a67cc",nonce="7ab30335732156f2569263035abb0956",opaque="",cnonce="5fb77d40",qop=auth,nc=00000001,algorithm=MD5
Supported: replaces,join,sdp-anat,norefersub,resource-priority,extended-refer,X-cisco-callinfo,X-cisco-serviceuri,X-cisco-escapecodes,X-cisco-service-control,X-cisco-srtp-fallback,X-cisco-monrec,X-cisco-config,X-cisco-sis-7.0.0,X-cisco-xsi-8.5.1
Content-Length: 0
The only difference is the presence of the authorization data in 8865. Someone knows why 8831 does not send the authorization field ?
I attach the configuration file.
