8831 Wireless Menu option gone
jenniferharper
I have some 8831 with Wireless mics that we upgraded the firmware to sip8831.10-3-1SR3-5. The wireless mics are unpaired.  When you go the IP phone information there is no longer an option for the wireless mics.  We have done a factory reset, a soft reset(using apps) and hard reset on the device and we completed wiped the phone out and rebuilt the device and Still, the wireless option in the menu is missing. Any ideas?
hmccloud
I was told that wireless microphones are disabled in the sip8831.10-3-1SR3-5 firmware and
are re-enabled once the 8831 is upgraded to the region-specific version of the firmware. For
example, if you upgrade to cmterm-8831-sip.10-3-1SR3-5-NA for North America, this should
resolve your problem.  The reasoning for this was that different countries have different regulations
about what wireless frequencies are allowed to be emitted by devices.
5 Replies 5
Jaime Valencia
Have you tried downgrading to the FW you had before?
java
if this helps, please rate
Yes, did that also.  Still nothing
Manish Gogna
Hi Jennifer,
As per the release notes for this firmware:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cuipph/8831/firmware/10-3-1-sr3/cs38_b_rn-8831-8831nr-1031sr3.html#reference_08DFEEE91DCAEAFA81146145ED276BAD
Please take a note of the things that i have highlighted in bold, these need to be taken care of:
Before You Begin
Before using Cisco Unified IP Phone Firmware Release 10.3(1)SR3 with Cisco Unified Communications Manager, you must install the latest firmware on all Cisco Unified Communications Manager servers in the cluster.
Procedure
    Step 1   Go to the following URL:
    http:/​/​www.cisco.com/​cisco/​software/​navigator.html?mdfid=268437892&flowid=5293
    Step 2   Choose Cisco Unified IP Phones 8800 Series.
    Step 3   Choose Cisco Unified IP Conference Phone 8831.
    Step 4   Choose Session Initiation Protocol (SIP) Software.
    Step 5   In the All Releases folder, expand the SIPv.10 folder and choose 10.3(1).
    Step 6   Select the file cmterm-8831-sip.9-3-3-TO-10-3-1-v2.cop.sgn, click the Download Now or Add to cart button, and follow the prompts.
    Note
    If you added the firmware file to the cart, click the Download Cart link when you are ready to download the file.
    Step 7   Click the + next to the firmware filename in the Download Cart section to access additional information about this file. The hyperlink for the readme file is in the Additional Information section, which contains installation instructions for the corresponding firmware:
    cmterm-8831-sip.9-3-3-TO-10-3-1-v2-readme.html
    Step 8   Follow the instructions in the readme file to install the firmware.
    Step 9   Return to the firmware download page.
    Step 10   In the Latest Releases folder, choose 10.3(1)SR3.
    Step 11   Select the required region-specific file as described in the following table, click the Download Now or Add to cart button, and follow the prompts.
    Table 2 Wireless Microphone Regions and Firmware Loads
    Region
    Region-Specific Firmware
    North America
    cmterm-8831-sip.10-3-1SR3-4-NA.cop.sgn
    Europe
    cmterm-8831-sip.10-3-1SR3-4-EU.cop.sgn
    Latin America
    cmterm-8831-sip.10-3-1SR3-4-LA.cop.sgn
    Brazil
    cmterm-8831-sip.10-3-1SR3-4-BR.cop.sgn
    Taiwan
    cmterm-8831-sip.10-3-1SR3-4-TW.cop.sgn
    Japan
    cmterm-8831-sip.10-3-1SR3-4-JP.cop.sgn
    Note
    Step 12   Click the + next to the firmware filename in the Download Cart section to access additional information about this file. The hyperlink for the readme file is in the Additional Information section, which contains installation instructions for the corresponding firmware.
    Step 13   If the Cisco Unified Communications Manager Device Pack to support this release is not available, download the file cmterm-8831-QED-1031-4.k3.cop.sgn and install it on the Cisco Unified Communications Manager.
    Step 14   Follow the instructions in the readme file to install the firmware.
    This should take care of the issue.
    Manish
    - Do rate helpful posts -
    Latest firmware  means you need to install the latest device pack for cucm based on your cucm version.
    hmccloud
