01-15-2019 07:27 AM - edited 03-17-2019 01:56 PM
Hi.
I have cisco cp-8832 and cp-8832-pwr adapter. Can I make it work via Wi-Fi without buying Ethernet injector?
There is no "Admin settings > Network setup > Wi-Fi client setup" out of the box. Is there a way to unlock this settings.
fw 12-0-1SR3-1
Thank you.
Solved! Go to Solution.
01-16-2019 12:50 AM
1) To Unlock Wi-FI option you have to connect the Phone at lease once via LAN and register to CUCM.
2) Enable the Wifi in CUCM and configure WLAN Profile as perbelow guide Section. Phone will register via LAN and download configuration
3) Now You have to disconnect Ethernet. Then you will be able to connect to WiFi
**** Please rate and mark correct answer as applicable.
LINKS
Step 1 |
To enable the wireless LAN on a specific phone, perform the following steps:
Select Device > Phone.
Locate the required phone.
Select the Enabled setting for the Wi-Fi parameter in the Product Specific Configuration Layout section.
Check the Override Common Settings check box. |
Step 2 |
To enable wireless LAN for a group of phones,
Select Device > Device Settings > Common Phone Profile.
Select the Enabled setting for the Wi-Fi parameter.
Associate the phones with that common phone profile using Device > Phone. |
Step 3 |
To enable wireless LAN for all WLAN-capable phones in your network,
Select System > Enterprise Phone Configuration.
The Wi-Fi client setup option does not appear in the Network setup menu when Wi-Fi is disabled on the Cisco Unified Communications Manager. |
01-15-2019 10:51 PM
01-16-2019 12:50 AM
LINKS
Step 1 |
Step 2 |
Step 3 |
01-16-2019 01:28 AM
So, no way to make it work without Ethernet injector.
This one-USB design is a really great thing.
Thank you.
