8841 device configuration rejection
RoyceSarusal
Beginner
Beginner
I am trying to configure a CP8841 in call manager 12.5. As soon as I save the configuration, the config rejects. If I delete the new device config to start over and instead do a copy from a same model that is registered, I still get rejected on the copied device. The MAC first character is D and, for no other reason than to see if it makes any difference, I changed that first character to A, saved, then B, saved, etc.. Rejected status clears if I use any other A-F character besides D.
Can someone tell me what this is telling me is wrong?
Jaime Valencia
Hall of Fame Cisco Employee Hall of Fame Cisco Employee
Are you sure you are using the right device model?
Is that device running enterprise FW or MPP/3PCC FW?
java
if this helps, please rate
Recognize Your Peers
