06-07-2022 09:57 AM
Is it possible to create a sip trunk grouping for a single outbound dial-peer voice?
Something similar happens for E1 with (trunk group), so you can add a single dial-peer and apply the preference to sip trunk from different operators.
Example:
dial-peer voice 12 pots
trunkgroup PSTNA 1
trunkgroup PSTNB 2
description -------------[LDN]
preference 1
destination-pattern 00[^0][^0][2-5].......
on digit-strip
Solved! Go to Solution.
06-07-2022 11:13 AM
06-07-2022 11:13 AM
06-09-2022 12:08 PM
Hi Mohammed Al Baqari,
It sounds like just what I was looking for.
I have a new demand. A customer today has a CUCM cluster that serves 194 sites in my country. Each location has its own SRST gateway. He wants to remove the cost of these local gateways, and concentrate two CUBEs in different DataCenters here in my country, and two VoiP carriers (ITSP VIVO and OI) for contingency and redundancy.
However, I cannot create several dial-peers for each location. There is a limitation at this point.
The SIP trunks will occur with these carriers delivering +Country code+National code+Prefix/DDR (E164). I will have to base my outbound routes on analysis via calling and called number to direct to the correct peer.
Best regards,
