8841 IP Phone encounters reboot during the call with a reasonforoutofservice = 14
ccg-collab1
Level 2
Level 2
We would like to ask if what is the main root cause for the IP Phone that encountered unregistration issue with reason ReasonForOutOfService=14? As per checking, this reason means The Cisco Unified Communication Manager closed the TCP connection. May we know what are the reasons why CUCM closes the TCP connection of an IP Phone? Upon checking the logs, this IP Phone encountered the issue and the reason for all the encountered issue is 14. See below logs. Appreciate your inputs on this kind of issue. Thank you.
Line 30: Nov 09 23:22:08, PHEMSSSMW-CSUB2, Info, Cisco CallManager, : 187845: PHEMSSSMW-CSUB2 Nov 09 2017 15:22:08 UTC : %UC_CALLMANAGER-6-EndPointUnregistered: %[DeviceName=SEP84B517AF3520][IPAddress=10.161.210.64][Protocol=SIP][DeviceType=683][Description=SMW IP Phones - CP8841][Reason=8][IPAddrAttributes=0][ClusterID=StandAloneCluster][NodeID=PHEMSSSMW-CSUB2]: An endpoint has unregistered, 29
Line 34: Nov 09 23:22:17, PHEMSSSMW-CSUB2, Info, Cisco CallManager, : 187849: PHEMSSSMW-CSUB2 Nov 09 2017 15:22:17 UTC : %UC_-6-LastOutOfServiceInformation: %[DeviceName=SEP84B517AF3520][DeviceIPv4Address=/0][IPv4DefaultGateway=][DeviceIPv6Address=][IPv6DefaultGateway=][ModelNumber=CP-8841][NeighborIPv4Address=10.161.244.65][NeighborIPv6Address=][NeighborDeviceID=SHPHSMWASW19][NeighborPortID=GigabitEthernet4/0/38][DHCPv4Status=1][DHCPv6Status=3][TFTPCfgStatus=1][DNSStatusUnifiedCM1=4][DNSStatusUnifiedCM2=4][DNSStatusUnifiedCM3=4][DNSv6StatusUnifiedCM1=0][DNSv6StatusUnifiedCM2=0][DNSv6StatusUnifiedCM3=0][VoiceVLAN=310][UnifiedCMIPAddress=10.161.249.18][LocalPort=50021][TimeStamp=1510240931693][ReasonForOutOfService=20][LastProtocolEventSent=Sent:SIP/2.0 200 OK Cseq:101 NOTIFY CallId:52488e00-9f71b975-12acfb-12f9a10a@10.161.249.18][LastProtocolEventReceived=Rcvd:SIP/2.0 200 OK Cseq:2357 REGISTER CallId:84b517af-35200020-10e6e533-2155c24e@10.161.210.64][ClusterID=StandAloneCluster][NodeID=PHEMSSSMW-CSUB2]...
Line 35: Nov 09 23:22:17, PHEMSSSMW-CSUB2, Info, Cisco CallManager, : 187850: PHEMSSSMW-CSUB2 Nov 09 2017 15:22:17 UTC : %UC_-6-LastOutOfServiceInformation: %[DeviceName=SEP84B517AF3520][DeviceIPv4Address=10.161.210.64 / 0][IPv4DefaultGateway=10.161.210.1][DeviceIPv6Address=][IPv6DefaultGateway=][ModelNumber=CP-8841][NeighborIPv4Address=10.161.244.65][NeighborIPv6Address=][NeighborDeviceID=][NeighborPortID=GigabitEthernet4/0/][DHCPv4Status=1][DHCPv6Status=3][TFTPCfgStatus=1][DNSStatusUnifiedCM1=4][DNSStatusUnifiedCM2=4][DNSStatusUnifiedCM3=4][VoiceVLAN=310][UnifiedCMIPAddress=10.161.249.18][LocalPort=52999][TimeStamp=1510240931][ReasonForOutOfService=14][LastProtocolEventSent=][LastProtocolEventReceived=Rcvd:SIP/2.0 200 OK Cseq:2591 REGISTER CallId:84b517af-35200023-117597e9-7c043b4c@10.161.210.64][ClusterID=StandAloneCluster][NodeID=PHEMSSSMW-CSUB2]: Information related to the last out-of-service event, 34
Line 36: Nov 09 23:22:17, PHEMSSSMW-CSUB2, Error, Cisco CallManager, : 187851: PHEMSSSMW-CSUB2 Nov 09 2017 15:22:17 UTC : %UC_-3-DeviceTLInfo: %[DeviceName=SEP84B517AF3520][IPv4Address=10.161.210.64][IPv6Address=][CTL_Signature=Not Installed][CTL_TFTP_Server=N/A][ITL_Signature=ED 3A 2C 2E 81 A8 C7 A3 46 77 3A BD AA 54 9D 58 DE B6 DD ED ][ITL_TFTP_Server=PHEMSSSMW-CFTP1][UNKNOWN_PARAMTYPE:StatusCode=3][ClusterID=StandAloneCluster][NodeID=PHEMSSSMW-CSUB2]: Trust List Files are updated or installed, 35
Line 37: Nov 09 23:22:17, PHEMSSSMW-CSUB2, Info, Cisco CallManager, : 187852: PHEMSSSMW-CSUB2 Nov 09 2017 15:22:17 UTC : %UC_-6-LastOutOfServiceInformation: %[DeviceName=SEP84B517AF3520][DeviceIPv4Address=/0][IPv4DefaultGateway=][DeviceIPv6Address=][IPv6DefaultGateway=][ModelNumber=CP-8841][NeighborIPv4Address=10.161.244.65][NeighborIPv6Address=][NeighborDeviceID=SHPHSMWASW19][NeighborPortID=GigabitEthernet4/0/38][DHCPv4Status=1][DHCPv6Status=3][TFTPCfgStatus=1][DNSStatusUnifiedCM1=4][DNSStatusUnifiedCM2=4][DNSStatusUnifiedCM3=4][DNSv6StatusUnifiedCM1=0][DNSv6StatusUnifiedCM2=0][DNSv6StatusUnifiedCM3=0][VoiceVLAN=310][UnifiedCMIPAddress=10.161.249.18][LocalPort=52999][TimeStamp=1510240931693][ReasonForOutOfService=20][LastProtocolEventSent=Sent:SIP/2.0 200 OK Cseq:101 NOTIFY CallId:52488e00-9f71b975-12acfb-12f9a10a@10.161.249.18][LastProtocolEventReceived=Rcvd:SIP/2.0 200 OK Cseq:2591 REGISTER CallId:84b517af-35200023-117597e9-7c043b4c@10.161.210.64][ClusterID=StandAloneCluster][NodeID=PHEMSSSMW-CSUB2]...
Line 38: Nov 09 23:22:17, PHEMSSSMW-CSUB2, Info, Cisco CallManager, : 187853: PHEMSSSMW-CSUB2 Nov 09 2017 15:22:17 UTC : %UC_CALLMANAGER-6-EndPointRegistered: %[DeviceName=SEP84B517AF3520][IPAddress=10.161.210.64][Protocol=SIP][DeviceType=683][PerfMonObjType=2][Description=SMW IP Phones - CP8841][UserID=3532][LoadID=sip88xx.10-3-1-20][AssociatedDNs=+6325753532][MACAddress=84B517AF3520][IPAddrAttributes=0][ActiveLoadId=sip88xx.10-3-1-20.loads][InactiveLoadId=sip88xx.10-2-2-16.loads][ClusterID=StandAloneCluster][NodeID=PHEMSSSMW-CSUB2]: Endpoint registered, 37
Line 39: Nov 09 23:22:17, PHEMSSSMW-CSUB2, Info, Cisco CallManager, : 187854: PHEMSSSMW-CSUB2 Nov 09 2017 15:22:17 UTC : %UC_CALLMANAGER-6-DeviceDnInformation: %[DeviceName=SEP84B517AF3520][DeviceType=683][StationDesc=SMW IP Phones - CP8841][StationDn=+6325753532][ClusterID=StandAloneCluster][NodeID=PHEMSSSMW-CSUB2]: List of directory numbers (DN) associated with this device, 38
Line 1162: Nov 10 12:55:54, PHEMSSSMW-CSUB2, Info, Cisco CallManager, : 188977: PHEMSSSMW-CSUB2 Nov 10 2017 04:55:54 UTC : %UC_CALLMANAGER-6-EndPointUnregistered: %[DeviceName=SEP84B517AF3520][IPAddress=10.161.210.64][Protocol=SIP][DeviceType=683][Description=SMW IP Phones - CP8841][Reason=8][IPAddrAttributes=0][ClusterID=StandAloneCluster][NodeID=PHEMSSSMW-CSUB2]: An endpoint has unregistered, 1161
Line 1163: Nov 10 12:56:03, PHEMSSSMW-CSUB2, Info, Cisco CallManager, : 188978: PHEMSSSMW-CSUB2 Nov 10 2017 04:56:03 UTC : %UC_-6-LastOutOfServiceInformation: %[DeviceName=SEP84B517AF3520][DeviceIPv4Address=10.161.210.64 / 0][IPv4DefaultGateway=10.161.210.1][DeviceIPv6Address=][IPv6DefaultGateway=][ModelNumber=CP-8841][NeighborIPv4Address=10.161.244.65][NeighborIPv6Address=][NeighborDeviceID=][NeighborPortID=GigabitEthernet4/0/][DHCPv4Status=1][DHCPv6Status=3][TFTPCfgStatus=1][DNSStatusUnifiedCM1=4][DNSStatusUnifiedCM2=4][DNSStatusUnifiedCM3=4][VoiceVLAN=310][UnifiedCMIPAddress=10.161.249.18][LocalPort=50799][TimeStamp=1510289760][ReasonForOutOfService=14][LastProtocolEventSent=][LastProtocolEventReceived=Rcvd:SIP/2.0 200 OK Cseq:3016 REGISTER CallId:84b517af-35200025-28323708-7a90676e@10.161.210.64][ClusterID=StandAloneCluster][NodeID=PHEMSSSMW-CSUB2]: Information related to the last out-of-service event, 1162
Line 1164: Nov 10 12:56:03, PHEMSSSMW-CSUB2, Info, Cisco CallManager, : 188979: PHEMSSSMW-CSUB2 Nov 10 2017 04:56:03 UTC : %UC_-6-LastOutOfServiceInformation: %[DeviceName=SEP84B517AF3520][DeviceIPv4Address=/0][IPv4DefaultGateway=][DeviceIPv6Address=][IPv6DefaultGateway=][ModelNumber=CP-8841][NeighborIPv4Address=10.161.244.65][NeighborIPv6Address=][NeighborDeviceID=SHPHSMWASW19][NeighborPortID=GigabitEthernet4/0/38][DHCPv4Status=3][DHCPv6Status=3][TFTPCfgStatus=1][DNSStatusUnifiedCM1=4][DNSStatusUnifiedCM2=4][DNSStatusUnifiedCM3=4][DNSv6StatusUnifiedCM1=0][DNSv6StatusUnifiedCM2=0][DNSv6StatusUnifiedCM3=0][VoiceVLAN=310][UnifiedCMIPAddress=10.161.249.18][LocalPort=50799][TimeStamp=1510289760341][ReasonForOutOfService=14][LastProtocolEventSent=Sent:SIP/2.0 200 OK Cseq:101 NOTIFY CallId:52488e00-9f71b975-12acfb-12f9a10a@10.161.249.18][LastProtocolEventReceived=Rcvd:SIP/2.0 200 OK Cseq:3016 REGISTER CallId:84b517af-35200025-28323708-7a90676e@10.161.210.64][ClusterID=StandAloneCluster][NodeID=PHEMSSSMW-CSUB...
Line 1165: Nov 10 12:56:03, PHEMSSSMW-CSUB2, Error, Cisco CallManager, : 188980: PHEMSSSMW-CSUB2 Nov 10 2017 04:56:03 UTC : %UC_-3-DeviceTLInfo: %[DeviceName=SEP84B517AF3520][IPv4Address=10.161.210.64][IPv6Address=][CTL_Signature=Not Installed][CTL_TFTP_Server=N/A][ITL_Signature=ED 3A 2C 2E 81 A8 C7 A3 46 77 3A BD AA 54 9D 58 DE B6 DD ED ][ITL_TFTP_Server=PHEMSSSMW-CFTP1][UNKNOWN_PARAMTYPE:StatusCode=3][ClusterID=StandAloneCluster][NodeID=PHEMSSSMW-CSUB2]: Trust List Files are updated or installed, 1164
Line 1166: Nov 10 12:56:03, PHEMSSSMW-CSUB2, Info, Cisco CallManager, : 188981: PHEMSSSMW-CSUB2 Nov 10 2017 04:56:03 UTC : %UC_-6-LastOutOfServiceInformation: %[DeviceName=SEP84B517AF3520][DeviceIPv4Address=/0][IPv4DefaultGateway=][DeviceIPv6Address=][IPv6DefaultGateway=][ModelNumber=CP-8841][NeighborIPv4Address=10.161.244.65][NeighborIPv6Address=][NeighborDeviceID=SHPHSMWASW19][NeighborPortID=GigabitEthernet4/0/38][DHCPv4Status=3][DHCPv6Status=3][TFTPCfgStatus=1][DNSStatusUnifiedCM1=4][DNSStatusUnifiedCM2=4][DNSStatusUnifiedCM3=4][DNSv6StatusUnifiedCM1=0][DNSv6StatusUnifiedCM2=0][DNSv6StatusUnifiedCM3=0][VoiceVLAN=310][UnifiedCMIPAddress=10.161.249.18][LocalPort=50799][TimeStamp=1510289760341][ReasonForOutOfService=14][LastProtocolEventSent=Sent:SIP/2.0 200 OK Cseq:101 NOTIFY CallId:52488e00-9f71b975-12acfb-12f9a10a@10.161.249.18][LastProtocolEventReceived=Rcvd:SIP/2.0 200 OK Cseq:3016 REGISTER CallId:84b517af-35200025-28323708-7a90676e@10.161.210.64][ClusterID=StandAloneCluster][NodeID=PHEMSSSMW-CSUB...
Line 1167: Nov 10 12:56:03, PHEMSSSMW-CSUB2, Info, Cisco CallManager, : 188982: PHEMSSSMW-CSUB2 Nov 10 2017 04:56:03 UTC : %UC_CALLMANAGER-6-EndPointRegistered: %[DeviceName=SEP84B517AF3520][IPAddress=10.161.210.64][Protocol=SIP][DeviceType=683][PerfMonObjType=2][Description=SMW IP Phones - CP8841][UserID=3532][LoadID=sip88xx.10-3-1-20][AssociatedDNs=+6325753532][MACAddress=84B517AF3520][IPAddrAttributes=0][ActiveLoadId=sip88xx.10-3-1-20.loads][InactiveLoadId=sip88xx.10-2-2-16.loads][ClusterID=StandAloneCluster][NodeID=PHEMSSSMW-CSUB2]: Endpoint registered, 1166
Line 1168: Nov 10 12:56:03, PHEMSSSMW-CSUB2, Info, Cisco CallManager, : 188983: PHEMSSSMW-CSUB2 Nov 10 2017 04:56:03 UTC : %UC_CALLMANAGER-6-DeviceDnInformation: %[DeviceName=SEP84B517AF3520][DeviceType=683][StationDesc=SMW IP Phones - CP8841][StationDn=+6325753532][ClusterID=StandAloneCluster][NodeID=PHEMSSSMW-CSUB2]: List of directory numbers (DN) associated with this device, 1167
Line 4323: Nov 10 22:04:29, PHEMSSSMW-CSUB2, Info, Cisco CallManager, : 192138: PHEMSSSMW-CSUB2 Nov 10 2017 14:04:29 UTC : %UC_CALLMANAGER-6-EndPointUnregistered: %[DeviceName=SEP84B517AF3520][IPAddress=10.161.210.64][Protocol=SIP][DeviceType=683][Description=SMW IP Phones - CP8841][Reason=8][IPAddrAttributes=0][ClusterID=StandAloneCluster][NodeID=PHEMSSSMW-CSUB2]: An endpoint has unregistered, 4322
Line 4324: Nov 10 22:04:29, PHEMSSSMW-CSUB2, Info, Cisco CallManager, : 192139: PHEMSSSMW-CSUB2 Nov 10 2017 14:04:29 UTC : %UC_-6-LastOutOfServiceInformation: %[DeviceName=SEP84B517AF3520][DeviceIPv4Address=/0][IPv4DefaultGateway=][DeviceIPv6Address=][IPv6DefaultGateway=][ModelNumber=CP-8841][NeighborIPv4Address=10.161.244.65][NeighborIPv6Address=][NeighborDeviceID=SHPHSMWASW19][NeighborPortID=GigabitEthernet4/0/38][DHCPv4Status=1][DHCPv6Status=3][TFTPCfgStatus=1][DNSStatusUnifiedCM1=4][DNSStatusUnifiedCM2=4][DNSStatusUnifiedCM3=4][DNSv6StatusUnifiedCM1=0][DNSv6StatusUnifiedCM2=0][DNSv6StatusUnifiedCM3=0][VoiceVLAN=310][UnifiedCMIPAddress=10.161.249.18][LocalPort=50799][TimeStamp=1510322675743][ReasonForOutOfService=20][LastProtocolEventSent=Sent:SIP/2.0 200 OK Cseq:101 NOTIFY CallId:52488e00-9f71b975-12acfb-12f9a10a@10.161.249.18][LastProtocolEventReceived=Rcvd:SIP/2.0 200 OK Cseq:3016 REGISTER CallId:84b517af-35200025-28323708-7a90676e@10.161.210.64][ClusterID=StandAloneCluster][NodeID=PHEMSSSMW-CSUB...
Line 4330: Nov 10 22:04:37, PHEMSSSMW-CSUB2, Info, Cisco CallManager, : 192145: PHEMSSSMW-CSUB2 Nov 10 2017 14:04:37 UTC : %UC_-6-LastOutOfServiceInformation: %[DeviceName=SEP84B517AF3520][DeviceIPv4Address=10.161.210.64 / 0][IPv4DefaultGateway=10.161.210.1][DeviceIPv6Address=][IPv6DefaultGateway=][ModelNumber=CP-8841][NeighborIPv4Address=10.161.244.65][NeighborIPv6Address=][NeighborDeviceID=][NeighborPortID=GigabitEthernet4/0/][DHCPv4Status=1][DHCPv6Status=3][TFTPCfgStatus=1][DNSStatusUnifiedCM1=4][DNSStatusUnifiedCM2=4][DNSStatusUnifiedCM3=4][VoiceVLAN=310][UnifiedCMIPAddress=10.161.249.18][LocalPort=51391][TimeStamp=1510322676][ReasonForOutOfService=14][LastProtocolEventSent=][LastProtocolEventReceived=Rcvd:SIP/2.0 202 Accepted Cseq:1000 REFER CallId:84b517af-35200032-71541b40-5381d276@10.161.210.64][ClusterID=StandAloneCluster][NodeID=PHEMSSSMW-CSUB2]: Information related to the last out-of-service event, 4329
Line 4331: Nov 10 22:04:37, PHEMSSSMW-CSUB2, Error, Cisco CallManager, : 192146: PHEMSSSMW-CSUB2 Nov 10 2017 14:04:37 UTC : %UC_-3-DeviceTLInfo: %[DeviceName=SEP84B517AF3520][IPv4Address=10.161.210.64][IPv6Address=][CTL_Signature=Not Installed][CTL_TFTP_Server=N/A][ITL_Signature=ED 3A 2C 2E 81 A8 C7 A3 46 77 3A BD AA 54 9D 58 DE B6 DD ED ][ITL_TFTP_Server=PHEMSSSMW-CFTP1][UNKNOWN_PARAMTYPE:StatusCode=3][ClusterID=StandAloneCluster][NodeID=PHEMSSSMW-CSUB2]: Trust List Files are updated or installed, 4330
Line 4332: Nov 10 22:04:37, PHEMSSSMW-CSUB2, Info, Cisco CallManager, : 192147: PHEMSSSMW-CSUB2 Nov 10 2017 14:04:37 UTC : %UC_-6-LastOutOfServiceInformation: %[DeviceName=SEP84B517AF3520][DeviceIPv4Address=/0][IPv4DefaultGateway=][DeviceIPv6Address=][IPv6DefaultGateway=][ModelNumber=CP-8841][NeighborIPv4Address=10.161.244.65][NeighborIPv6Address=][NeighborDeviceID=SHPHSMWASW19][NeighborPortID=GigabitEthernet4/0/38][DHCPv4Status=1][DHCPv6Status=3][TFTPCfgStatus=1][DNSStatusUnifiedCM1=4][DNSStatusUnifiedCM2=4][DNSStatusUnifiedCM3=4][DNSv6StatusUnifiedCM1=0][DNSv6StatusUnifiedCM2=0][DNSv6StatusUnifiedCM3=0][VoiceVLAN=310][UnifiedCMIPAddress=10.161.249.18][LocalPort=51391][TimeStamp=1510322675743][ReasonForOutOfService=20][LastProtocolEventSent=Sent:SIP/2.0 200 OK Cseq:101 NOTIFY CallId:52488e00-9f71b975-12acfb-12f9a10a@10.161.249.18][LastProtocolEventReceived=Rcvd:SIP/2.0 202 Accepted Cseq:1000 REFER CallId:84b517af-35200032-71541b40-5381d276@10.161.210.64][ClusterID=StandAloneCluster][NodeID=PHEMSSSMW-C...
Line 4333: Nov 10 22:04:37, PHEMSSSMW-CSUB2, Info, Cisco CallManager, : 192148: PHEMSSSMW-CSUB2 Nov 10 2017 14:04:37 UTC : %UC_CALLMANAGER-6-EndPointRegistered: %[DeviceName=SEP84B517AF3520][IPAddress=10.161.210.64][Protocol=SIP][DeviceType=683][PerfMonObjType=2][Description=SMW IP Phones - CP8841][UserID=3532][LoadID=sip88xx.10-3-1-20][AssociatedDNs=+6325753532][MACAddress=84B517AF3520][IPAddrAttributes=0][ActiveLoadId=sip88xx.10-3-1-20.loads][InactiveLoadId=sip88xx.10-2-2-16.loads][ClusterID=StandAloneCluster][NodeID=PHEMSSSMW-CSUB2]: Endpoint registered, 4332
Line 4334: Nov 10 22:04:37, PHEMSSSMW-CSUB2, Info, Cisco CallManager, : 192149: PHEMSSSMW-CSUB2 Nov 10 2017 14:04:37 UTC : %UC_CALLMANAGER-6-DeviceDnInformation: %[DeviceName=SEP84B517AF3520][DeviceType=683][StationDesc=SMW IP Phones - CP8841][StationDn=+6325753532][ClusterID=StandAloneCluster][NodeID=PHEMSSSMW-CSUB2]: List of directory numbers (DN) associated with this device, 4333
Line 6067: Nov 13 10:17:26, PHEMSSSMW-CSUB2, Info, Cisco CallManager, : 193882: PHEMSSSMW-CSUB2 Nov 13 2017 02:17:26 UTC : %UC_CALLMANAGER-6-EndPointUnregistered: %[DeviceName=SEP84B517AF3520][IPAddress=10.161.210.64][Protocol=SIP][DeviceType=683][Description=SMW IP Phones - CP8841][Reason=8][IPAddrAttributes=0][ClusterID=StandAloneCluster][NodeID=PHEMSSSMW-CSUB2]: An endpoint has unregistered, 6066
Line 6069: Nov 13 10:17:35, PHEMSSSMW-CSUB2, Info, Cisco CallManager, : 193884: PHEMSSSMW-CSUB2 Nov 13 2017 02:17:35 UTC : %UC_-6-LastOutOfServiceInformation: %[DeviceName=SEP84B517AF3520][DeviceIPv4Address=10.161.210.64 / 0][IPv4DefaultGateway=10.161.210.1][DeviceIPv6Address=][IPv6DefaultGateway=][ModelNumber=CP-8841][NeighborIPv4Address=10.161.244.65][NeighborIPv6Address=][NeighborDeviceID=][NeighborPortID=GigabitEthernet4/0/][DHCPv4Status=1][DHCPv6Status=3][TFTPCfgStatus=1][DNSStatusUnifiedCM1=4][DNSStatusUnifiedCM2=4][DNSStatusUnifiedCM3=4][VoiceVLAN=310][UnifiedCMIPAddress=10.161.249.18][LocalPort=51974][TimeStamp=1510539453][ReasonForOutOfService=14][LastProtocolEventSent=][LastProtocolEventReceived=Rcvd:SIP/2.0 200 OK Cseq:4977 REGISTER CallId:84b517af-35200028-2d631299-01779149@10.161.210.64][ClusterID=StandAloneCluster][NodeID=PHEMSSSMW-CSUB2]: Information related to the last out-of-service event, 6068
Line 6070: Nov 13 10:17:35, PHEMSSSMW-CSUB2, Info, Cisco CallManager, : 193885: PHEMSSSMW-CSUB2 Nov 13 2017 02:17:35 UTC : %UC_-6-LastOutOfServiceInformation: %[DeviceName=SEP84B517AF3520][DeviceIPv4Address=/0][IPv4DefaultGateway=][DeviceIPv6Address=][IPv6DefaultGateway=][ModelNumber=CP-8841][NeighborIPv4Address=10.161.244.65][NeighborIPv6Address=][NeighborDeviceID=SHPHSMWASW19][NeighborPortID=GigabitEthernet4/0/38][DHCPv4Status=3][DHCPv6Status=3][TFTPCfgStatus=1][DNSStatusUnifiedCM1=4][DNSStatusUnifiedCM2=4][DNSStatusUnifiedCM3=4][DNSv6StatusUnifiedCM1=0][DNSv6StatusUnifiedCM2=0][DNSv6StatusUnifiedCM3=0][VoiceVLAN=310][UnifiedCMIPAddress=10.161.249.18][LocalPort=51974][TimeStamp=1510539453869][ReasonForOutOfService=14][LastProtocolEventSent=Sent:SIP/2.0 200 OK Cseq:101 NOTIFY CallId:52488e00-9f71b975-12acfb-12f9a10a@10.161.249.18][LastProtocolEventReceived=Rcvd:SIP/2.0 200 OK Cseq:4977 REGISTER CallId:84b517af-35200028-2d631299-01779149@10.161.210.64][ClusterID=StandAloneCluster][NodeID=PHEMSSSMW-CSUB...
Line 6071: Nov 13 10:17:35, PHEMSSSMW-CSUB2, Error, Cisco CallManager, : 193886: PHEMSSSMW-CSUB2 Nov 13 2017 02:17:35 UTC : %UC_-3-DeviceTLInfo: %[DeviceName=SEP84B517AF3520][IPv4Address=10.161.210.64][IPv6Address=][CTL_Signature=Not Installed][CTL_TFTP_Server=N/A][ITL_Signature=ED 3A 2C 2E 81 A8 C7 A3 46 77 3A BD AA 54 9D 58 DE B6 DD ED ][ITL_TFTP_Server=PHEMSSSMW-CFTP1][UNKNOWN_PARAMTYPE:StatusCode=3][ClusterID=StandAloneCluster][NodeID=PHEMSSSMW-CSUB2]: Trust List Files are updated or installed, 6070
Line 6072: Nov 13 10:17:35, PHEMSSSMW-CSUB2, Info, Cisco CallManager, : 193887: PHEMSSSMW-CSUB2 Nov 13 2017 02:17:35 UTC : %UC_-6-LastOutOfServiceInformation: %[DeviceName=SEP84B517AF3520][DeviceIPv4Address=/0][IPv4DefaultGateway=][DeviceIPv6Address=][IPv6DefaultGateway=][ModelNumber=CP-8841][NeighborIPv4Address=10.161.244.65][NeighborIPv6Address=][NeighborDeviceID=SHPHSMWASW19][NeighborPortID=GigabitEthernet4/0/38][DHCPv4Status=3][DHCPv6Status=3][TFTPCfgStatus=1][DNSStatusUnifiedCM1=4][DNSStatusUnifiedCM2=4][DNSStatusUnifiedCM3=4][DNSv6StatusUnifiedCM1=0][DNSv6StatusUnifiedCM2=0][DNSv6StatusUnifiedCM3=0][VoiceVLAN=310][UnifiedCMIPAddress=10.161.249.18][LocalPort=51974][TimeStamp=1510539453869][ReasonForOutOfService=14][LastProtocolEventSent=Sent:SIP/2.0 200 OK Cseq:101 NOTIFY CallId:52488e00-9f71b975-12acfb-12f9a10a@10.161.249.18][LastProtocolEventReceived=Rcvd:SIP/2.0 200 OK Cseq:4977 REGISTER CallId:84b517af-35200028-2d631299-01779149@10.161.210.64][ClusterID=StandAloneCluster][NodeID=PHEMSSSMW-CSUB...
Line 6073: Nov 13 10:17:35, PHEMSSSMW-CSUB2, Info, Cisco CallManager, : 193888: PHEMSSSMW-CSUB2 Nov 13 2017 02:17:35 UTC : %UC_CALLMANAGER-6-EndPointRegistered: %[DeviceName=SEP84B517AF3520][IPAddress=10.161.210.64][Protocol=SIP][DeviceType=683][PerfMonObjType=2][Description=SMW IP Phones - CP8841][UserID=3532][LoadID=sip88xx.10-3-1-20][AssociatedDNs=+6325753532][MACAddress=84B517AF3520][IPAddrAttributes=0][ActiveLoadId=sip88xx.10-3-1-20.loads][InactiveLoadId=sip88xx.10-2-2-16.loads][ClusterID=StandAloneCluster][NodeID=PHEMSSSMW-CSUB2]: Endpoint registered, 6072
Line 6074: Nov 13 10:17:35, PHEMSSSMW-CSUB2, Info, Cisco CallManager, : 193889: PHEMSSSMW-CSUB2 Nov 13 2017 02:17:35 UTC : %UC_CALLMANAGER-6-DeviceDnInformation: %[DeviceName=SEP84B517AF3520][DeviceType=683][StationDesc=SMW IP Phones - CP8841][StationDn=+6325753532][ClusterID=StandAloneCluster][NodeID=PHEMSSSMW-CSUB2]: List of directory numbers (DN) associated with this device, 6073
0 Replies 0
