05-11-2015 11:20 AM - edited 03-17-2019 02:57 AM
Hello!
I use a script its-CISCO.2.0.3.0.tcl for AA services in CME 10.5. Script config:
application
service aa flash:its-CISCO.2.0.3.0.tcl
paramspace english index 0
paramspace english language en
param operator 21
paramspace english location flash:
paramspace english prefix en
param aa-pilot 4999
dial-peer voice 4999 voip
service aa
destination-pattern 4999
session target ipv4:172.16.1.1
incoming called-number 4999
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
voice-port 0/2/0
connection plar opx 4999
impedance complex1
caller-id enable
Script works, but I do not see caller-id on destination phone. I see on phone caller-id 4999. Also when an external line attempts to connect through the system, but the external POTS phone disconnects before the IP phone user picks up – the IP phone will ring FOREVER – until the IP phone is taken off-hook.
What can cause the problem?
Kamil
05-11-2015 11:46 AM
When I remove "dial-peer voice 4999 voip" and set:
dial-peer voice 301 pots
service aa
incoming called-number .%
direct-inward-dial
port 0/2/0
I have "Unknown number".
Whats wrong?
Kamil
06-15-2016 04:54 AM
SOLVED??!!
11-13-2017 02:46 AM
What did you done that solved that.
12-10-2016 03:28 PM
Do you know if this script works in SRST mode with sccp and sip ip phones?
Thanks.
