- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
04-05-2019 12:24 PM
My phone's running sip8845_65.12-5-1-SR1-4 firmware. When I go to admin settings I'm prompted for a password. I haven't a clue what this password is, or where its set. I've tried "cisco" and "Cisco" as I've seen it suggested elsewhere. Also "**#" and "**#**". Also, I've factory reset several times (unplug and hold pound key 'til the microphone light goes out and 1-9 + *0#).
Could someone explain to me what's happening here, and where this setting is set? Other phones on my network, in the same device pool, running the same firmware ...aren't asking for the administrator password here.
System Version:11.5.1.12900-21
Solved! Go to Solution.
- Labels:
IP Phones and Accessories
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-07-2019 03:58 AM
1) If you are able to register the phone to CUCM then just go to devices>Phones and look for settings access and set it to Enabled.
You will not be prompted for the password
2) if you want to change the password then you can change it via common phone profile> Local Phone Unlock Password.
NOTE:- If you change in common phone profile it will impact all phone. You can create a profile dedicated for this phone.
*** Please rate helpful post; Mark "Accept as a Solution" if applicable
Haris
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-05-2019 12:42 PM
Hi @Wayne Ficklin ,
Just to discard, check this video to verify that your factory reset is ok.
https://www.youtube.com/watch?v=SdNgFmANw5o
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-05-2019 01:20 PM
I did it again, just like he showed in the video. I didn't know to watch for the mic light to turn red after 1-9 + *0#. Each time I reset I lose my wallpaper setting (and power cycling doesn't do that) so I think I've done it correctly each time.
That said, after trying it again, I'm still prompted for an administrator password when I go to Admin settings from the applications/gear button.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-05-2019 03:20 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-07-2019 03:58 AM
Haris
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-08-2019 05:35 AM
Settings Access is already set to enabled.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-08-2019 05:45 AM
...but I checked the Common Device Profile and deleted the unlock password there, and now I'm able to access the menu.
Thanks for your help.
ps. Settings Access restricts access to most of the options after pressing the Settings (gear) button. The "Admin Settings" option wasn't even displayed when I went and disabled "Settings Access".
