08-15-2024
08:26 AM
- last edited on
08-15-2024
09:32 AM
by
rupeshah
Cisco 8845 will not start video from axis I8116-E door station until camera shutter is toggled on or off. When call comes in from Axis door station there is no video. If I change the position of the camera from open to closed or from closed to open video will start.
Solved! Go to Solution.
08-21-2024 07:08 AM
Axis tech support directed me to install latest firmware, and set the Video profile to "baseline" in the SIP account settings.
One I8116-E was already at latest firmware and I was able to set the H.264 profile to "baseline" as suggested. This fixed the problem.
The second door station required an upgrade to latest and I was then able to edit the H.264 profile as requested.
Both stations are now 100% operable.
08-15-2024 02:48 PM - edited 08-15-2024 02:49 PM
Does the Axis device send an early offer INVITE that includes video SDP lines? If not then ask Axis support how to fix that.
The shutter closed/open is probably triggering a SIP re-INVITE from the endpoint to drop and add video. CUCM should be extending those re-INVITEs to the Axis, at which point both sides agree.
CUCM SDL logs would confirm all of this.
08-21-2024 07:08 AM
