8865 CME registration problem
Grishazahid
Hello community!
I have a problem in connecting 8865 IP Phone to CME (version 12.0 , Cisco 891 router)
Phone succesfully receives IP , an then contacting TFTP server in search of SEPAC7E8AB6C34D.cnf.xml.sgn
I made this file using samples for 7960 model(SEP<MAC>.cnf.xml), but registration unsuccesful
Can someone share proper config file for 8865 phone?
Router's config
Spoiler
Router#sh run
Building configuration...
Current configuration : 2522 bytes
! Last configuration change at 12:52:09 EEST Wed Jun 27 2018
version 15.7
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
clock timezone EET 2 0
clock summer-time EEST recurring
ip dhcp pool POOL1
 network 192.168.0.0 255.255.255.0
 default-router 192.168.0.1
 option 150 ip 192.168.0.2
ip cef
no ipv6 cef
voice service voip
 allow-connections sip to sip
 sip
  registrar server expires max 1200 min 300
voice register global
 mode cme
 source-address 192.168.0.1 port 5060
 max-dn 5
 max-pool 5
 authenticate register
 authenticate realm cisco.com
 auto-register
voice register dn  1
 number 1001
 allow watch
 name Phone1
 label 10011001
voice register pool  1
 busy-trigger-per-button 2
 id mac AC7E.8AB6.C34D
 type 8865
 number 1 dn 1
 username user1 password cisco
 codec g711ulaw
license udi pid CISCO891-K9 sn FTX171383YK
username grisha privilege 15 password 0 hardpass
redundancy
interface FastEthernet0
 no ip address
interface FastEthernet1
 no ip address
interface FastEthernet2
 no ip address
interface FastEthernet3
 no ip address
interface FastEthernet4
 no ip address
interface FastEthernet5
 no ip address
interface FastEthernet6
 no ip address
interface FastEthernet7
 no ip address
interface FastEthernet8
 no ip address
 shutdown
 duplex auto
 speed auto
interface GigabitEthernet0
 ip address dhcp
 duplex auto
 speed auto
interface Vlan1
 ip address 192.168.0.1 255.255.255.0
interface Async1
 no ip address
 encapsulation slip
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip http path flash:/CME-GUI-12.0
ipv6 ioam timestamp
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
telephony-service
 time-format 24
 date-format dd-mm-yy
 max-conferences 0 gain -6
 web admin system name grishazahid password hardpass
 web admin customer name cusadmin password cisco
 dn-webedit
 time-webedit
 transfer-system full-consult
 vstack
line con 0
line 1
 speed 115200
line aux 0
line vty 0 4
 login local
 transport input telnet
ntp server 34.202.215.187
end
Router#
Spoiler
<device>
    <fullConfig>true</fullConfig>
    <deviceProtocol>SIP</deviceProtocol>
    <devicePool>
        <dateTimeSetting>
            <dateTemplate>D.M.Y</dateTemplate>
            <timeZone>Ekaterinburg Standard Time</timeZone>
            <ntps>
                <ntp>
                    <name>192.168.0.1</name>
                    <ntpMode>Unicast</ntpMode>
                </ntp>
            </ntps>
        </dateTimeSetting>
        <callManagerGroup>
            <tftpDefault>true</tftpDefault>
                <members>
                <member priority="0">
                <callManager>
                <description>Station</description>
                <ports>
                  <ethernetPhonePort>2000</ethernetPhonePort>
                  <sipPort>5060</sipPort>
                  <securedSipPort>5061</securedSipPort>
                </ports>
                <processNodeName>192.168.0.1</processNodeName>
                </callManager>
                </member>
                </members>
             </callManagerGroup>
    </devicePool>
    <commonProfile>
        <phonePassword></phonePassword>
        <backgroundImageAccess>true</backgroundImageAccess>
        <callLogBlfEnabled>0</callLogBlfEnabled>
    </commonProfile>
    <vendorConfig>
        <disableSpeaker>false</disableSpeaker>
        <disableSpeakerAndHeadset>false</disableSpeakerAndHeadset>
        <pcPort>0</pcPort>
        <settingsAccess>1</settingsAccess>
        <garp>0</garp>
        <voiceVlanAccess>0</voiceVlanAccess>
        <videoCapability>0</videoCapability>
        <autoSelectLineEnable>0</autoSelectLineEnable>
        <daysDisplayNotActive>1,7</daysDisplayNotActive>
        <displayOnTime>10:30</displayOnTime>
        <displayOnDuration>06:05</displayOnDuration>
        <displayIdleTimeout>00:05</displayIdleTimeout>
        <webAccess>0</webAccess>
        <spanToPCPort>1</spanToPCPort>
        <loggingDisplay>1</loggingDisplay>
        <loadServer></loadServer>
    </vendorConfig>
    <deviceSecurityMode>1</deviceSecurityMode>
    <idleTimeout>0</idleTimeout>
    <directoryURL></directoryURL>
    <servicesURL>$SERVICESURL</servicesURL>
    <idleURL></idleURL>
    <messagesURL></messagesURL>
    <proxyServerURL></proxyServerURL>
    <dscpForSCCPPhoneConfig>96</dscpForSCCPPhoneConfig>
    <dscpForSCCPPhoneServices>0</dscpForSCCPPhoneServices>
    <dscpForCm2Dvce>96</dscpForCm2Dvce>
    <transportLayerProtocol>2</transportLayerProtocol>
    <capfAuthMode>0</capfAuthMode>
    <capfList>
        <capf>
            <phonePort>3804</phonePort>
        </capf>
    </capfList>
    <certHash></certHash>
    <encrConfig>false</encrConfig>
    <sipProfile>
        <sipProxies>
            <backupProxy>192.168.0.1</backupProxy>
            <backupProxyPort>5060</backupProxyPort>
            <emergencyProxy>192.168.0.1</emergencyProxy>
            <emergencyProxyPort>5060</emergencyProxyPort>
            <outboundProxy>192.168.0.1</outboundProxy>
            <outboundProxyPort>5060</outboundProxyPort>
            <registerWithProxy>true</registerWithProxy>
        </sipProxies>
     <sipCallFeatures>
        <cnfJoinEnabled>true</cnfJoinEnabled>
        <callForwardURI>x--serviceuri-cfwdall</callForwardURI>
        <callPickupURI>x-cisco-serviceuri-pickup</callPickupURI>
        <callPickupListURI>x-cisco-serviceuri-opickup</callPickupListURI>
        <callPickupGroupURI>x-cisco-serviceuri-gpickup</callPickupGroupURI>
        <meetMeServiceURI>x-cisco-serviceuri-meetme</meetMeServiceURI>
        <abbreviatedDialURI>x-cisco-serviceuri-abbrdial</abbreviatedDialURI>
        <rfc2543Hold>false</rfc2543Hold>
        <callHoldRingback>2</callHoldRingback>
        <localCfwdEnable>true</localCfwdEnable>
        <semiAttendedTransfer>true</semiAttendedTransfer>
        <anonymousCallBlock>2</anonymousCallBlock>
        <callerIdBlocking>2</callerIdBlocking>
        <dndControl>0</dndControl>
        <remoteCcEnable>true</remoteCcEnable>
     </sipCallFeatures>
     <sipStack>
        <sipInviteRetx>6</sipInviteRetx>
        <sipRetx>10</sipRetx>
        <timerInviteExpires>180</timerInviteExpires>
        <timerRegisterExpires>3600</timerRegisterExpires>
        <timerRegisterDelta>5</timerRegisterDelta>
        <timerKeepAliveExpires>120</timerKeepAliveExpires>
        <timerSubscribeExpires>120</timerSubscribeExpires>
        <timerSubscribeDelta>5</timerSubscribeDelta>
        <timerT1>500</timerT1>
        <timerT2>4000</timerT2>
        <maxRedirects>70</maxRedirects>
        <remotePartyID>false</remotePartyID>
        <userInfo>None</userInfo>
     </sipStack>
     <autoAnswerTimer>1</autoAnswerTimer>
     <autoAnswerAltBehavior>false</autoAnswerAltBehavior>
     <autoAnswerOverride>true</autoAnswerOverride>
     <transferOnhookEnabled>false</transferOnhookEnabled>
     <enableVad>false</enableVad>
        <preferredCodec>g711ulaw</preferredCodec>
       <dtmfAvtPayload>101</dtmfAvtPayload>
       <dtmfDbLevel>3</dtmfDbLevel>
       <dtmfOutofBand>avt</dtmfOutofBand>
        <alwaysUsePrimeLine>false</alwaysUsePrimeLine>
        <alwaysUsePrimeLineVoiceMail>false</alwaysUsePrimeLineVoiceMail>
        <kpml>3</kpml>
        <stutterMsgWaiting>1</stutterMsgWaiting>
        <callStats>true</callStats>
        <silentPeriodBetweenCallWaitingBursts>10</silentPeriodBetweenCallWaitingBursts>
        <disableLocalSpeedDialConfig>true</disableLocalSpeedDialConfig>
        <startMediaPort>10100</startMediaPort>
        <stopMediaPort>10300</stopMediaPort>
        <voipControlPort>5060</voipControlPort>
        <dscpForAudio>184</dscpForAudio>
        <ringSettingBusyStationPolicy>0</ringSettingBusyStationPolicy>
        <dialTemplate>dialplan.xml</dialTemplate>
        <phoneLabel>Cisco</phoneLabel>
          <natReceivedProcessing>false</natReceivedProcessing>
          <natEnabled>false</natEnabled>
          <natAddress></natAddress>
        <sipLines>
          <line button="1">
            <featureID>9</featureID>
            <featureLabel>1001</featureLabel>
            <proxy>192.168.0.1</proxy>
            <port>5060</port>
            <name>1001</name>
            <displayName>1001</displayName>
            <autoAnswer>
              <autoAnswerEnabled>2</autoAnswerEnabled>
            </autoAnswer>
            <callWaiting>3</callWaiting>
            <authName>user1</authName>
            <authPassword>cisco</authPassword>
            <sharedLine>false</sharedLine>
            <messageWaitingLampPolicy>3</messageWaitingLampPolicy>
            <messagesNumber></messagesNumber>
            <ringSettingIdle>4</ringSettingIdle>
            <ringSettingActive>5</ringSettingActive>
            <contact>1001</contact>
            <forwardCallInfoDisplay>
              <callerName>true</callerName>
              <callerNumber>false</callerNumber>
              <redirectedNumber>false</redirectedNumber>
              <dialedNumber>true</dialedNumber>
            </forwardCallInfoDisplay>
          </line>
          <line button="2">
          <featureID></featureID>
          <featureLabel></featureLabel>
          <speedDialNumber></speedDialNumber>
          </line>
        </sipLines>
    </sipProfile>
</device>
M02@rt37
Hi @Grishazahid
The config file that your ip phone try to download is a signed file SEP----.cnf.xml.sgn extension instead of your SEP---.cnf.xml.
The sgn mean signed file (by an certification authority via capf server).
It's due to that the phone was already registered in secure cluster.
Then do a factory reset.
And don'f forget to do a create profile in the voice register global menu in order to generate your SEP---.cnf.xml config file.
Best regards
M02@rt37
Hi @Grishazahid
Best regards
Thanks for reply
I reset the phone.
Then I found some manual https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/admin/configuration/manual/cmeadm/cmefiles.html#ucme_t_genconfig-sip
and do the following
2.    configure terminal
3.    voice register global
4.    file text
5.    create profile
after this some files appeared:
Router#show voice register tftp-bind
tftp-server url system:/cme/sipphone/syncinfo.xml alias syncinfo.xml
tftp-server url system:/cme/sipphone/SIPDefault.cnf alias SIPDefault.cnf
tftp-server url system:/cme/sipphone/softkeyDefault_kpml.xml alias softkeyDefault_kpml.xml
tftp-server url system:/cme/sipphone/softkeyDefault.xml alias softkeyDefault.xml
tftp-server url system:/cme/sipphone/featurePolicyDefault.xml alias featurePolicyDefault.xml
tftp-server url system:/cme/sipphone/SEPAC7E8AB6C34D.cnf.xml alias SEPAC7E8AB6C34D.cnf.xml
i copied file SEPAC7E8AB6C34D.cnf.xml to my tftp server
AND THERE IS A SUCCESS!! :) Thanks!
*Jun 27 14:02:28.174: %SIPPHONE-6-REGISTER: VOICE REGISTER POOL-1 has registered. Name:SEPAC7E8AB6C34D  IP:192.168.0.9  DeviceType:Phone
Ok @Grishazahid
Happy for you.
Don't forget to add the ntp-server command on your voice register global menu. Re do a create profile and restart all the ip phone.
Finally, the file text command generate an ASCII text file version of the configuration profiles for Cisco Unified IP Phone 7905s and 7905Gs, Cisco Unified IP Phone 7912s and 7912Gs, Cisco ATA-186s, or Cisco ATA-188s.
Best regards
