06-27-2018 07:00 AM - edited 03-17-2019 01:06 PM
Hello community!
I have a problem in connecting 8865 IP Phone to CME (version 12.0 , Cisco 891 router)
Phone succesfully receives IP , an then contacting TFTP server in search of SEPAC7E8AB6C34D.cnf.xml.sgn
I made this file using samples for 7960 model(SEP<MAC>.cnf.xml), but registration unsuccesful
Can someone share proper config file for 8865 phone?
Router's config
Router#sh run Building configuration... Current configuration : 2522 bytes ! ! Last configuration change at 12:52:09 EEST Wed Jun 27 2018 ! version 15.7 service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption ! hostname Router ! boot-start-marker boot-end-marker ! ! ! no aaa new-model clock timezone EET 2 0 clock summer-time EEST recurring ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ip dhcp pool POOL1 network 192.168.0.0 255.255.255.0 default-router 192.168.0.1 option 150 ip 192.168.0.2 ! ! ! ip cef no ipv6 cef ! ! ! ! ! multilink bundle-name authenticated ! ! ! ! voice service voip allow-connections sip to sip sip registrar server expires max 1200 min 300 ! ! ! voice register global mode cme source-address 192.168.0.1 port 5060 max-dn 5 max-pool 5 authenticate register authenticate realm cisco.com auto-register ! ! voice register dn 1 number 1001 allow watch name Phone1 label 10011001 ! voice register pool 1 busy-trigger-per-button 2 id mac AC7E.8AB6.C34D type 8865 number 1 dn 1 username user1 password cisco codec g711ulaw ! ! ! license udi pid CISCO891-K9 sn FTX171383YK ! ! username grisha privilege 15 password 0 hardpass ! redundancy ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! interface FastEthernet0 no ip address ! interface FastEthernet1 no ip address ! interface FastEthernet2 no ip address ! interface FastEthernet3 no ip address ! interface FastEthernet4 no ip address ! interface FastEthernet5 no ip address ! interface FastEthernet6 no ip address ! interface FastEthernet7 no ip address ! interface FastEthernet8 no ip address shutdown duplex auto speed auto ! interface GigabitEthernet0 ip address dhcp duplex auto speed auto ! interface Vlan1 ip address 192.168.0.1 255.255.255.0 ! interface Async1 no ip address encapsulation slip ! ip forward-protocol nd ip http server ip http authentication local no ip http secure-server ip http path flash:/CME-GUI-12.0 ! ! ! ipv6 ioam timestamp ! ! ! control-plane ! ! mgcp behavior rsip-range tgcp-only mgcp behavior comedia-role none mgcp behavior comedia-check-media-src disable mgcp behavior comedia-sdp-force disable ! mgcp profile default ! ! ! ! ! ! ! telephony-service time-format 24 date-format dd-mm-yy max-conferences 0 gain -6 web admin system name grishazahid password hardpass web admin customer name cusadmin password cisco dn-webedit time-webedit transfer-system full-consult ! ! vstack ! line con 0 line 1 speed 115200 line aux 0 line vty 0 4 login local transport input telnet ! ntp server 34.202.215.187 ! end Router#
<device> <fullConfig>true</fullConfig> <deviceProtocol>SIP</deviceProtocol> <devicePool> <dateTimeSetting> <dateTemplate>D.M.Y</dateTemplate> <timeZone>Ekaterinburg Standard Time</timeZone> <ntps> <ntp> <name>192.168.0.1</name> <ntpMode>Unicast</ntpMode> </ntp> </ntps> </dateTimeSetting> <callManagerGroup> <tftpDefault>true</tftpDefault> <members> <member priority="0"> <callManager> <name>192.168.0.1</name> <description>Station</description> <ports> <ethernetPhonePort>2000</ethernetPhonePort> <sipPort>5060</sipPort> <securedSipPort>5061</securedSipPort> </ports> <processNodeName>192.168.0.1</processNodeName> </callManager> </member> </members> </callManagerGroup> </devicePool> <commonProfile> <phonePassword></phonePassword> <backgroundImageAccess>true</backgroundImageAccess> <callLogBlfEnabled>0</callLogBlfEnabled> </commonProfile> <vendorConfig> <disableSpeaker>false</disableSpeaker> <disableSpeakerAndHeadset>false</disableSpeakerAndHeadset> <pcPort>0</pcPort> <settingsAccess>1</settingsAccess> <garp>0</garp> <voiceVlanAccess>0</voiceVlanAccess> <videoCapability>0</videoCapability> <autoSelectLineEnable>0</autoSelectLineEnable> <daysDisplayNotActive>1,7</daysDisplayNotActive> <displayOnTime>10:30</displayOnTime> <displayOnDuration>06:05</displayOnDuration> <displayIdleTimeout>00:05</displayIdleTimeout> <webAccess>0</webAccess> <spanToPCPort>1</spanToPCPort> <loggingDisplay>1</loggingDisplay> <loadServer></loadServer> </vendorConfig> <deviceSecurityMode>1</deviceSecurityMode> <idleTimeout>0</idleTimeout> <directoryURL></directoryURL> <servicesURL>$SERVICESURL</servicesURL> <idleURL></idleURL> <messagesURL></messagesURL> <proxyServerURL></proxyServerURL> <dscpForSCCPPhoneConfig>96</dscpForSCCPPhoneConfig> <dscpForSCCPPhoneServices>0</dscpForSCCPPhoneServices> <dscpForCm2Dvce>96</dscpForCm2Dvce> <transportLayerProtocol>2</transportLayerProtocol> <capfAuthMode>0</capfAuthMode> <capfList> <capf> <phonePort>3804</phonePort> </capf> </capfList> <certHash></certHash> <encrConfig>false</encrConfig> <sipProfile> <sipProxies> <backupProxy>192.168.0.1</backupProxy> <backupProxyPort>5060</backupProxyPort> <emergencyProxy>192.168.0.1</emergencyProxy> <emergencyProxyPort>5060</emergencyProxyPort> <outboundProxy>192.168.0.1</outboundProxy> <outboundProxyPort>5060</outboundProxyPort> <registerWithProxy>true</registerWithProxy> </sipProxies> <sipCallFeatures> <cnfJoinEnabled>true</cnfJoinEnabled> <callForwardURI>x--serviceuri-cfwdall</callForwardURI> <callPickupURI>x-cisco-serviceuri-pickup</callPickupURI> <callPickupListURI>x-cisco-serviceuri-opickup</callPickupListURI> <callPickupGroupURI>x-cisco-serviceuri-gpickup</callPickupGroupURI> <meetMeServiceURI>x-cisco-serviceuri-meetme</meetMeServiceURI> <abbreviatedDialURI>x-cisco-serviceuri-abbrdial</abbreviatedDialURI> <rfc2543Hold>false</rfc2543Hold> <callHoldRingback>2</callHoldRingback> <localCfwdEnable>true</localCfwdEnable> <semiAttendedTransfer>true</semiAttendedTransfer> <anonymousCallBlock>2</anonymousCallBlock> <callerIdBlocking>2</callerIdBlocking> <dndControl>0</dndControl> <remoteCcEnable>true</remoteCcEnable> </sipCallFeatures> <sipStack> <sipInviteRetx>6</sipInviteRetx> <sipRetx>10</sipRetx> <timerInviteExpires>180</timerInviteExpires> <timerRegisterExpires>3600</timerRegisterExpires> <timerRegisterDelta>5</timerRegisterDelta> <timerKeepAliveExpires>120</timerKeepAliveExpires> <timerSubscribeExpires>120</timerSubscribeExpires> <timerSubscribeDelta>5</timerSubscribeDelta> <timerT1>500</timerT1> <timerT2>4000</timerT2> <maxRedirects>70</maxRedirects> <remotePartyID>false</remotePartyID> <userInfo>None</userInfo> </sipStack> <autoAnswerTimer>1</autoAnswerTimer> <autoAnswerAltBehavior>false</autoAnswerAltBehavior> <autoAnswerOverride>true</autoAnswerOverride> <transferOnhookEnabled>false</transferOnhookEnabled> <enableVad>false</enableVad> <preferredCodec>g711ulaw</preferredCodec> <dtmfAvtPayload>101</dtmfAvtPayload> <dtmfDbLevel>3</dtmfDbLevel> <dtmfOutofBand>avt</dtmfOutofBand> <alwaysUsePrimeLine>false</alwaysUsePrimeLine> <alwaysUsePrimeLineVoiceMail>false</alwaysUsePrimeLineVoiceMail> <kpml>3</kpml> <stutterMsgWaiting>1</stutterMsgWaiting> <callStats>true</callStats> <silentPeriodBetweenCallWaitingBursts>10</silentPeriodBetweenCallWaitingBursts> <disableLocalSpeedDialConfig>true</disableLocalSpeedDialConfig> <startMediaPort>10100</startMediaPort> <stopMediaPort>10300</stopMediaPort> <voipControlPort>5060</voipControlPort> <dscpForAudio>184</dscpForAudio> <ringSettingBusyStationPolicy>0</ringSettingBusyStationPolicy> <dialTemplate>dialplan.xml</dialTemplate> <phoneLabel>Cisco</phoneLabel> <natReceivedProcessing>false</natReceivedProcessing> <natEnabled>false</natEnabled> <natAddress></natAddress> <sipLines> <line button="1"> <featureID>9</featureID> <featureLabel>1001</featureLabel> <proxy>192.168.0.1</proxy> <port>5060</port> <name>1001</name> <displayName>1001</displayName> <autoAnswer> <autoAnswerEnabled>2</autoAnswerEnabled> </autoAnswer> <callWaiting>3</callWaiting> <authName>user1</authName> <authPassword>cisco</authPassword> <sharedLine>false</sharedLine> <messageWaitingLampPolicy>3</messageWaitingLampPolicy> <messagesNumber></messagesNumber> <ringSettingIdle>4</ringSettingIdle> <ringSettingActive>5</ringSettingActive> <contact>1001</contact> <forwardCallInfoDisplay> <callerName>true</callerName> <callerNumber>false</callerNumber> <redirectedNumber>false</redirectedNumber> <dialedNumber>true</dialedNumber> </forwardCallInfoDisplay> </line> <line button="2"> <featureID></featureID> <featureLabel></featureLabel> <speedDialNumber></speedDialNumber> </line> </sipLines> </sipProfile> </device>
Solved! Go to Solution.
06-27-2018 07:09 AM - edited 06-27-2018 07:13 AM
Hi @Grishazahid
The config file that your ip phone try to download is a signed file SEP----.cnf.xml.sgn extension instead of your SEP---.cnf.xml.
The sgn mean signed file (by an certification authority via capf server).
It's due to that the phone was already registered in secure cluster.
Then do a factory reset.
And don'f forget to do a create profile in the voice register global menu in order to generate your SEP---.cnf.xml config file.
Hi @Grishazahid
06-27-2018 07:55 AM
Thanks for reply
I reset the phone.
Then I found some manual https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/admin/configuration/manual/cmeadm/cmefiles.html#ucme_t_genconfig-sip
and do the following
2. configure terminal
3. voice register global
4. file text
5. create profile
after this some files appeared:
Router#show voice register tftp-bind
tftp-server url system:/cme/sipphone/syncinfo.xml alias syncinfo.xml
tftp-server url system:/cme/sipphone/SIPDefault.cnf alias SIPDefault.cnf
tftp-server url system:/cme/sipphone/softkeyDefault_kpml.xml alias softkeyDefault_kpml.xml
tftp-server url system:/cme/sipphone/softkeyDefault.xml alias softkeyDefault.xml
tftp-server url system:/cme/sipphone/featurePolicyDefault.xml alias featurePolicyDefault.xml
tftp-server url system:/cme/sipphone/SEPAC7E8AB6C34D.cnf.xml alias SEPAC7E8AB6C34D.cnf.xml
i copied file SEPAC7E8AB6C34D.cnf.xml to my tftp server
AND THERE IS A SUCCESS!! :) Thanks!
*Jun 27 14:02:28.174: %SIPPHONE-6-REGISTER: VOICE REGISTER POOL-1 has registered. Name:SEPAC7E8AB6C34D IP:192.168.0.9 DeviceType:Phone
06-27-2018 08:30 AM
Ok @Grishazahid
Happy for you.
Don't forget to add the ntp-server command on your voice register global menu. Re do a create profile and restart all the ip phone.
Finally, the file text command generate an ASCII text file version of the configuration profiles for Cisco Unified IP Phone 7905s and 7905Gs, Cisco Unified IP Phone 7912s and 7912Gs, Cisco ATA-186s, or Cisco ATA-188s.
