8865 MPP to Enterprise firmware conversion failure.
RG979797
Hello All.
Hope all is well during the holidays.
Have a quick question. I am having no luck converting a single 8865 MMP phone firmware to Enterprise phone so that it can register onto the CUCM.
We have bought the conversion license for the unit.
I have uploaded the below requested firmware onto the TFTP server.
Following this CIsco guide - https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cuipph/MPP/MPP-conversion/mpp-to-enterprise/tpcc_b_7800-8800-miration-guide-mpp-to/tpcc_b_7800-8800-miration-guide-mpp-to_chapter_01.html
Once I try to do the conversion I get this error on the phone.
Firmware Upgrade Status
Firmware Upgrade Status 1: [12/29/2021 05:10:16][tftp://X.X.X.X:69/sip8845_65.12-8-1-0101-482.loads]Upgrade Failed. Reason: Transition authorization failure
Logs from the TFTP server
Connection received from x.x.x.x on port 51383 [29/12 14:10:15.523]
Read request for file <sip8845_65.12-8-1-0101-482.loads>. Mode octet [29/12 14:10:15.523]
Using local port 54465 [29/12 14:10:15.523]
<sip8845_65.12-8-1-0101-482.loads>: sent 3 blks, 1303 bytes in 0 s. 0 blk resent [29/12 14:10:15.523]
Connection received from 10.253.1.1 on port 52693 [29/12 14:15:29.493]
Read request for file <sip8845_65.12-8-1-0101-482.loads>. Mode octet [29/12 14:15:29.493]
Using local port 54234 [29/12 14:15:29.493]
<sip8845_65.12-8-1-0101-482.loads>: sent 3 blks, 1303 bytes in 0 s. 0 blk resent [29/12 14:15:29.493]
I have upgraded the MPP to the latest version  - 8845_65.11-3-1MPP.
These are the debug logs from the  8865 Phone.
4266 NOT Dec 29 13:10:09.212505 (610:610) ms-AECAPI.aec_sendMsg AEC_SET_MUTE [msgID=4][msgLen=4]
4267 NOT Dec 29 13:10:09.212536 (610:610) ms-ACOUSTINTER.acoustici_setMute set mute[1]
4268 NOT Dec 29 13:10:09.212559 (610:610) ms-aomxSource_setMute: successfully set mute[1].
4269 NOT Dec 29 13:10:09.212575 (610:610) ms-DSPMGR.dm_mute Successfully to mute
4270 NOT Dec 29 13:10:09.212687 (1137:1137) mphone-CCallProxy_service(): [PXY]svcrecv QPE_VOIP_MSG_SYSTEM_AUDIO_PATH argc=3
4271 NOT Dec 29 13:10:09.213092 (610:610) ms-APATH.ms_setMute [setting mute off]
4272 NOT Dec 29 13:10:09.213124 (610:610) ms-aomxSource_setMute: successfully set mute[0].
4273 NOT Dec 29 13:10:09.213143 (610:610) ms-DSPMGR.dm_mute Successfully to unmute
4274 NOT Dec 29 13:10:09.213198 (928:978) voice-PHN_SET_AUDIO_PATH: Audio Path set to None, clearing MS SW mute
4275 NOT Dec 29 13:10:09.473802 (928:975) voice-fapp-CP-8865-3PCC d4:ad:bd:d0:81:09 -- Requesting upgrade tftp://TFTP-IP Add:69/sip8845_65.12-8-1-0101-482.loads
4276 NOT Dec 29 13:10:09.473934 (928:975) voice-fprv_download_file_img using default port 69
4277 NOT Dec 29 13:10:09.474099 (928:975) voice-fprv_download_file_img TFTP-IP Add:69 /sip8845_65.12-8-1-0101-482.loads [uid pwd len 0]
4278 NOT Dec 29 13:10:09.474190 (928:975) voice-FSTR_SERVER:TFTP-IP Add
4279 NOT Dec 29 13:10:09.474246 (928:975) voice-parse_ipv4v6_addr addr:TFTP-IP Add
4280 NOT Dec 29 13:10:09.475067 (928:975) voice-fprv_download_file_img-TLM: Checking transition authorization (type=Classic)...
4281 NOT Dec 29 13:10:09.475271 (568:568) downd-DDFORK - execing [/usr/sbin/dimg][-L2304][-a]
4282 CRT Dec 29 13:10:09.475800 (568:568) downd-WAITING FOR image
4283 NOT Dec 29 13:10:09.482610 (1137:1137) mphone-CCallProxy_service(): [PXY]svcrecv QPE_VOIP_MSG_SYSTEM_FIRMWARE_UPGRADE argc=3
4284 NOT Dec 29 13:10:09.482757 (1137:1137) mphone-CScreen_dispatch(): call agent process <Application_TransitionStart>
4285 NOT Dec 29 13:10:09.514106 (20614:20614) dimg-DIMG_ABORT killing image related processes
4286 NOT Dec 29 13:10:09.908640 (20614:20614) dimg-DOWNLOAD METHOD IS 0
4287 NOT Dec 29 13:10:09.908704 (20614:20614) dimg-TLM: Forked image LOAD AUTHORIZE command:
4288 NOT Dec 29 13:10:09.908722 (20614:20614) dimg-TLM: parameters:
4289 NOT Dec 29 13:10:09.908738 (20614:20614) dimg-TLM: /usr/sbin/image
4290 NOT Dec 29 13:10:09.908752 (20614:20614) dimg-TLM: -vLsip8845_65.12-8-1-0101-482.loads
4291 NOT Dec 29 13:10:09.908766 (20614:20614) dimg-TLM: -t
4292 NOT Dec 29 13:10:09.908781 (20614:20614) dimg-TLM: TFTP-IP Add
4293 NOT Dec 29 13:10:09.908795 (20614:20614) dimg-TLM: -c69
4294 NOT Dec 29 13:10:09.908809 (20614:20614) dimg-TLM:
4295 NOT Dec 29 13:10:09.908822 (20614:20614) dimg-TLM: -A
4296 NOT Dec 29 13:10:09.908836 (20614:20614) dimg-TLM: -x
4297 NOT Dec 29 13:10:09.908849 (20614:20614) dimg-TLM: 0
4298 NOT Dec 29 13:10:09.908862 (20614:20614) dimg-TLM: -z
4299 NOT Dec 29 13:10:09.908875 (20614:20614) dimg-TLM: <Trans_Auth_Rule ua="na">http://TFTP-IP Add/prov/migration/D4ADBDD08109.lic</Trans_Auth_Rule>
4300 NOT Dec 29 13:10:09.908889 (20614:20614) dimg-TLM:
4301 NOT Dec 29 13:10:09.940157 (20651:20651) img-***-startup [pid=20651]
4302 NOT Dec 29 13:10:09.946097 (20651:20651) img-***-ip ( 10.253.7.74 )
4303 NOT Dec 29 13:10:09.968346 (20651:20651) img-***-TLM: Image is running in Transition Load Mode
4304 NOT Dec 29 13:10:09.968479 (20651:20651) img-***-TLM: Direction: MPP to Enterprise
4305 NOT Dec 29 13:10:09.968537 (20651:20651) img-***-TLM:
4306 NOT Dec 29 13:10:09.968599 (20651:20651) img-***-ITRACE-command_parse-icmd.c
4307 NOT Dec 29 13:10:09.968706 (20651:20651) img-***-ICMD: VERBOSITY ENABLED
4308 NOT Dec 29 13:10:09.968812 (20651:20651) img-***-ICMD: LOAD [prefix= | load=sip8845_65.12-8-1-0101-482.loads]
4309 NOT Dec 29 13:10:09.968872 (20651:20651) img-***-ICMD: LOAD [withdir=sip8845_65.12-8-1-0101-482.loads
4310 NOT Dec 29 13:10:09.968924 (20651:20651) img-***-ICMD: [tftp=TFTP-IP Add]
4311 NOT Dec 29 13:10:09.968994 (20651:20651) img-***-ICMD: USING port 69
4312 NOT Dec 29 13:10:09.969057 (20651:20651) img-***-ICMD: AUTHORIZE ONLY
4313 NOT Dec 29 13:10:09.969138 (20651:20651) img-***-ICMD: [Trans Load Auth Rule=<Trans_Auth_Rule ua="na">http://TFTP-IP Add/prov/migration/D4ADBDD08109.lic</Trans_Auth_Rule>]
4314 NOT Dec 29 13:10:09.969201 (20651:20651) img-***-TLM: Transition Load Auth Rule detected in image startup
4315 NOT Dec 29 13:10:09.969252 (20651:20651) img-***-TLM:
4316 CRT Dec 29 13:10:09.989107 (568:568) downd-FOUND image
4317 INF Dec 29 13:10:09.992365 (20651:20656) img-***-SIGNAL HUP/INITIAL TRC Processing...
4318 NOT Dec 29 13:10:09.992510 (20651:20651) img-***-TLM: Locking out incompatible options
4319 NOT Dec 29 13:10:09.992579 (20651:20651) img-***-TLM: PFS: not selected
4320 NOT Dec 29 13:10:09.992604 (20651:20651) img-***-TLM:
4321 NOT Dec 29 13:10:09.992993 (20651:20651) img-***-TLM: Attempting to authorize transition...
4322 NOT Dec 29 13:10:09.993035 (20651:20651) img-***-TLM: (Authorization only pass)
4323 NOT Dec 29 13:10:10.017428 (20651:20651) img-***-TLM:
4324 NOT Dec 29 13:10:10.018339 (20651:20651) img-***-TLM: Transition Load Authorization Rule
4325 NOT Dec 29 13:10:10.018373 (20651:20651) img-***-TLM: Rule: <Trans_Auth_Rule ua="na">http://TFTP-IP Add/prov/migration/D4ADBDD08109.lic</Trans_Auth_Rule>
4326 NOT Dec 29 13:10:10.018422 (20651:20651) img-***-TLM: Filename: Trans_Auth_Rule>
4327 NOT Dec 29 13:10:10.018449 (20651:20651) img-***-TLM: Fetching license file Trans_Auth_Rule> ...
4328 NOT Dec 29 13:10:10.018501 (20651:20651) img-***-getByCurl -- reqByCurlInternal
4329 NOT Dec 29 13:10:10.018608 (20651:20651) img-***-reqByCurlInternal isHttps 0 isNand 0 pSrvName null pSrvIP null url <Trans_Auth_Rule ua="na">http://TFTP-IP Add/prov/migration/D4ADBDD08109.lic</Trans_Auth_Rule> pDestFileName (null) pSrcFileName (null) ua (null) ip_version 0
4330 NOT Dec 29 13:10:10.026117 (20651:20651) img-***-setAuthUserAgent:1047 auth set up done res=0 uid len 0 pwd len 0
4331 NOT Dec 29 13:10:10.026269 (20651:20651) img-***-buildHttpReqHeader adding accept header, Accept: */*
4332 NOT Dec 29 13:10:10.026338 (20651:20651) img-***-buildHttpReqHeader adding language header Accept-Language: en
4333 NOT Dec 29 13:10:10.026395 (20651:20651) img-***-buildHttpReqHeader adding charset header, Accept-Charset: iso-8859-1
4334 NOT Dec 29 13:10:10.026477 (20651:20651) img-***-reqByCurlInternal accept_encoding=
4335 NOT Dec 29 13:10:10.026567 (20651:20651) img-***-reqByCurlInternal sending http request out..., url:
4336 INF Dec 29 13:10:10.026746 (20651:20651) img-***-HTTP JNI| Curl_do_perform: enter
4337 INF Dec 29 13:10:10.026903 (20651:20651) img-***-HTTP JNI| connect_host: enter
4338 INF Dec 29 13:10:10.026987 (20651:20651) img-***-HTTP JNI| Curl_connect: enter
4339 INF Dec 29 13:10:10.027136 (20651:20651) img-***-HTTP JNI| parseurlandfillconn: hit6, protop:http
4340 INF Dec 29 13:10:10.029430 (20651:20651) img-***-HTTP JNI| Curl_do_perform: connect_host res=6
4341 NOT Dec 29 13:10:10.029618 (20651:20651) img-***-reqByCurlInternal return from http request, [res] = 6 Couldn't resolve host name
4342 NOT Dec 29 13:10:10.029708 (20651:20651) img-***-reqByCurlInternal last connection was to IP:
4343 NOT Dec 29 13:10:10.029964 (20651:20651) img-***-reqByCurlInternal exit rc 102
4344 NOT Dec 29 13:10:10.030031 (20651:20651) img-***-TLM: ERROR: Curl download failed - curl_rc = 102
4345 NOT Dec 29 13:10:10.030087 (20651:20651) img-***-TLM: (Authorization only pass) result: Transition NOT AUTHORIZED
4346 ERR Dec 29 13:10:10.038780 (20651:20651) img-***-EXITING...
4347 NOT Dec 29 13:10:10.083262 (20671:20671) imgpfs: -ebr-active = TLexM2E-11-3-4C-330
4348 NOT Dec 29 13:10:10.083459 (20671:20671) imgpfs: -Active = 2
4349 NOT Dec 29 13:10:10.088148 (20671:20671) imgpfs: -ebr_a [81] sip8845_65.11-1-1MPP-897.loads
4350 NOT Dec 29 13:10:10.093055 (20671:20671) imgpfs: -ebr_b [80] sip8845_65.TLexM2E-11-3-4C-330.loads
4351 NOT Dec 29 13:10:10.237124 (20651:20651) img-***-Post-Image Archive of Logs
4352 NOT Dec 29 13:10:10.872094 (20651:20651) img-***-pid_imgui >=0
4353 NOT Dec 29 13:10:11.080717 (685:718) CDP-cdpRcvPkt(): deviceId is STM-CHN-Sw2.stm.priv
4354 ERR Dec 29 13:10:11.102823 (20614:20614) dimg-/workspace/ip_sl/BLD-slm_mpp_1134_throttle-git-d_2/ip_sl/infra/lib/cisco/cisco_system2.c: 20614, EXITED: 173
4355 NOT Dec 29 13:10:11.103071 (20614:20614) dimg-IMAGE.actualserver [TFTP-IP Add]
4356 NOT Dec 29 13:10:11.118678 (928:975) voice-fprv_download_file_img-TLM: ...Transition authorization <<<FAIL>>> [173] _173_ Error in transition authorization code
4357 NOT Dec 29 13:10:11.118774 (928:975) voice-fprv_download_file_img-TLM: Downloading transition destination load...
4358 NOT Dec 29 13:10:11.118815 (928:975) voice-PFS IS ENABLED FOR THIS UPGRADE
4359 NOT Dec 29 13:10:11.118838 (928:975) voice-PFS OPTIONS ARE
4360 NOT Dec 29 13:10:11.118854 (928:975) voice-fprv_download_file_img requested load to upgrade is neither in active nor in inactive partition. Downloading and upgrading to the requested load
4361 NOT Dec 29 13:10:11.118992 (568:568) downd-DDFORK - execing [/usr/sbin/dimg][-L2304][-l]
4362 CRT Dec 29 13:10:11.119579 (568:568) downd-WAITING FOR image
4363 NOT Dec 29 13:10:11.123089 (1137:1137) mphone-CCallProxy_service(): [PXY]svcrecv QPE_VOIP_MSG_SYSTEM_FIRMWARE_UPGRADE argc=3
4364 NOT Dec 29 13:10:11.143849 (20614:20614) dimg-DIMG.RESULT [_173_ Error in transition authorization code
Any assistance on this issue is appreciated. Many thanks and happy holidays.
paulmorgan2000
Did you ever manage to resolve this??
