This sounds mostly as a security/routing issue.
Can you compare the IP address (on the Phone) and Authentication Profile/GroupPolicy (on ISE) when the phone is on your switch with the settings when the phone connects to the rest of your network?
Do you have an operational phone on the rest of your enviroment? Can you check the logs on ISE?
George
Please Rate Posts (by clicking on Star) and/or Mark Solutions as Accepted, when applies
