8945 Speed Dial
opnineopnine
I have a new 8945 and I can't make the speed dial to show up on the phone, I have configured this directly from the cucm and for self care web page.
Any ideas?
Thanks .
Jaime Valencia
Did you configure a button layout with speed dials??
java
if this helps, please rate
yes sir
devils_advocate
Level 7
Level 7
So within CUCM you have added the Speed Dials to the Device itself and they are not showing on the buttons of the handset itself?
Have you applied the config at the top and reset the phone?
