8945 Video questions
billmatthews
I'm looking at the datasheets for the 8945.  I had two questions about video:
-If I place a call between two 8945 within the same CUCM, will video be automatic?  Can the user turn on/off video via a button?
-Do they support sending video into a webex?
Jaime Valencia
Depends on whether you configure automatic video or not, yes, user has the option to turn on/off their video on a video call.
java
if this helps, please rate
Excellent thank you, +5
Does anyone happen to know about WebEx video from the 8945?
