10-20-2014 12:56 AM - edited 03-17-2019 12:36 AM
Hi All
I have installed a Cisco 8961 IP phone, we initially logged it on with a 7962 profile, when transferring a call, we had the option to resume it via a softkey!
However the BLF's were not working with this profile, so I then created a UDP for that phone, the BLF's not work, however the transfer softkey has now disappeared!
any ideas how to sort this ?
cheers
10-20-2014 03:40 AM
Hi.
Transfer function, has now a dedicated physical button on 89XX model.
http://www.cisco.com/c/en/us/products/collaboration-endpoints/unified-ip-phone-8900-series/datasheet-listing.html
Carlo
10-20-2014 05:11 AM
Yes, we press the transfer key which is a hard key, but when we press the BLF key to transfer the number to, there normally appears a transfer softkey and a resume softkey, these do not work!
10-20-2014 03:51 AM
Hi Carl,
I am not sure whether these bugs are exactly related to your issue.
Known Affected Releases: | (1) |
Presence BLF support on Call History feature development
CSCtq39163
Symptom:
This feature is a parity of the TNP phones. It enables the users to see the presence status of the line numbers in the Call History list for 9971/9951/8961.
Conditions:
Enable the enterprise parameter "BLF For Call Lists".
Workaround:
None
Customer Visible
Save Bug
Open Support Case
Was the description about this Bug Helpful?
(0)
Last Modified:
Oct 15,2012
Status:
Fixed
Severity:
6 Enhancement
Product:
Cisco Unified IP Phones 9900 Series
Support Cases:
9.2(3)
Known Fixed Releases: | (3) |
9.2(1)CH1.10
9.2(1)CH1.11
9.2(1)CH1.14
regds,
aman
