911 calls failing
pbrackett1
I am working with a network phone system running CUCM 10, alongside CER and some other similar systems. Inside the phone network, calls to 911 are failing. The caller gets a rapid busy signal when they try. I can see the attempts in the CER call history, and I do receive the emergency alert notification ("Alert, caller at extension XXXX is in emergency."). The call router (a Cisco C2911) shows the calls being made (see the attached log for an example). My telecom is reporting that the calls are being denied because they are not properly defined. They have pointed to a couple of specific lines in the log file from my router:
Called Party Number i = 0x80, '911'
Plan:Unknown, Type:Unknown
Anyone have any ideas. I'm in over my head and could really use some assistance.
33 Replies 33
It’s impossible to give you an answer on this based upon the limited information given here. For one it looks like you have not set an inbound CSS on the SIP trunk and without that inbound calls to you from the gateway will not work.
If you take screenshots of all settings on the SIP trunk and also of all settings of your H.323 gateway then we can compare these and determine if you have completely configured the needed values on the SIP trunk.
Response Signature
pbrackett1
Sorry for the delay. Too many other fish frying... First, the settings for the H.323 gateway:
pbrackett1
And second, the settings for my new SIP trunk:
This is what I see that you should look into as it's different between the two.
Response Signature
