9951 w/ CME dialing issues
rosalesr
I am currently experiencing issues while attempting place phone calls from a 9951 that is registered to CME. The ability to dial/call is intermittent. It does not matter how I attempt to dial (e.g. from directory or manual) it sometimes works and sometimes does not. Whenever I attempt to call, I get the following message on CME:
imageattr parse payload numtok not found imageattr payload found, specific is 255
I am currently running CME 8.8 on a 2951 w/ IOS 15.2 (4) M2, and 9951's running on 9.2.2.
Any help would be greatly appreciated.
Karthik Sivaram
Level 4
Level 4
Could be CSCtr33108 .
Move to IOS  15.2(2)T and use the latest firmware for 9951.
Hope this Helps!
Karthik
voicewiztim
Did you find out what the problem is to this? I see the same errors on my CUBE but I'm running UCM with SIP Trunks
