9971 KEM background color code?
Does anybody know the color code (hex, rgb or cmyk) of 9971 KEM backround? And/Or KEM buttons color code?
Cisco official colors from Brand_Guide_2006_interim.pdf do not match...
Thank you!
6 Replies 6
Deepak Rawat
You can program feature key buttons on the Cisco Unified IP Color Key Expansion Module as a directory number, line key, or speed-dial key. The buttons are illuminated, and when configured as a directory number or shared-line keys they allow for easy identification of call state. This capability provides features that are similar to those of typical direct station selection/busy lamp field (DSS/BLF) modules but are not intended to be directly comparable to those of traditional DSS/BLF modules.
Reference:
http://www.cisco.com/c/en/us/products/collateral/collaboration-endpoints/unified-ip-color-key-expansion-module/data_sheet_c78-565427.html
Deepak
I just want to make phone wallpaper that exactly fits the KEM color.
So if I understand you correctly, you want to change the background color of LCD display for the KEM to match it with the phone wallpaper. If that is correct, then I am afraid it is not possible, you can only adjust the brightness and that's it.
There is no way to set a background image on KEM or change the color display on it whatsoever.
Deepak
Vice versa.
I want to change the phone wallpaper to match the KEM module color.
I understand that it is not possible to change the KEM background.
I just can't find the color that is used in KEM background.\
Well to be honest there is not a document that talks the color that comes in the background of KEM-C. Hence, you would need to rely on what you see there on the KEM itself and then try to match the closest color for the phone wallpaper.
Deepak
that's impossible
