AA for branch site . unity as primary , tcl as backup
aasaadsavola
I am trying to configure Branch router for the customer to  have :
1) AA from unity connection as Primary
2|) User Local TCL  script AA as backup in case of primary failure.
when i try to call the main number , the Local TCL AA ALWAYS start  even if the WAN to Unity connection in HQ is up.
main number : 2687000
AA Pilot number : 8067000  in untiy and TCL
please the attached file for full config
your support
Aseem Anand
You need to make sure that the incoming dial-peer which gets matched does not contain the service command. For example you can create a new dial-peer with incoming called number set to exactly match the number received from Telco and specify the service on the outgoing dial-peer
dial-peer voice 71 pots
translation-profile incoming DNIS
incoming called-number 8067000
direct-inward-dial
port 0/1/0:23
Aseem
Thanks for your reply.
I want to Make Unity AA  as primary   and TCL Script in Local GW as Backup.
so you said apply service auto attend tcl  on outgoing dial-peer
what is destination pattern  ? Local Voice Gateway ?
can you clarify more.?
