aa not working on 1760-v router
Dear All,
I am trying to configure CME 4.1 on 1760-v router for my home purpose. you can find attach sh run, sh inventory and incomming call-log on fxo port, which i got from "debug vpm all" and "terminal monitor" commnads. call is coming to fxo port and moved to aap.tcl script ( inside the flash with all audio.au files), and then sometimes its disconnected immediately, and sometimes keep connected for 10 to 12 sec and then disconnected.
Any idea, what going wrong? is it codec issue? PVDM?
sh version is also attached
ITCS#terminal moni
ITCS#
ITCS#
ITCS#
ITCS#debug vpm all
All Voice Port Module debugging is enabled
Note: DSP message debugging is not part of this command.
Use debug vpm dsp to enable it
ITCS#
*Mar  3 22:46:16.062: htsp_process_event: [2/1, FXOLS_ONHOOK, E_DSP_SIG_0000]fxo
ls_onhook_ringing
*Mar  3 22:46:16.062: TGRM: reg_invoke_tgrm_call_update(0, 2, 1, 65535, 1, TGRM_
CALL_PENDING, TGRM_CALL_VOICE, TGRM_DIRECTION_IN)
*Mar  3 22:46:16.062: htsp_timer - 125 msec
*Mar  3 22:46:16.082: htsp_process_event: [2/0, FXOLS_ONHOOK, E_DSP_SIG_0000]fxo
ls_onhook_ringing
*Mar  3 22:46:16.082: TGRM: reg_invoke_tgrm_call_update(0, 2, 0, 65535, 1, TGRM_
*Mar  3 22:46:16.086: htsp_timer - 125 msec
*Mar  3 22:46:16.174: htsp_process_event: [2/1, FXOLS_WAIT_RING_MIN, E_DSP_SIG_0
100]fxols_ringing_disc
*Mar  3 22:46:16.174: htsp_timer_stop3
*Mar  3 22:46:16.174: TGRM: reg_invoke_tgrm_call_update(0, 2, 1, 65535, 1, TGRM_
CALL_IDLE, TGRM_CALL_VOICE, TGRM_DIRECTION_IN)
*Mar  3 22:46:16.194: htsp_process_event: [2/0, FXOLS_WAIT_RING_MIN, E_DSP_SIG_0
*Mar  3 22:46:16.194: htsp_timer_stop3
*Mar  3 22:46:16.194: TGRM: reg_invoke_tgrm_call_update(0, 2, 0, 65535, 1, TGRM_
ITCS#
ITCS#sh version
Cisco IOS Software, C1700 Software (C1700-ADVENTERPRISEK9-M), Version 12.4(15)T
RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Mon 25-Jun-07 18:39 by prod_rel_team
ROM: System Bootstrap, Version 12.2(7r)XM2, RELEASE SOFTWARE (fc1)
ITCS uptime is 1 day, 10 hours, 49 minutes
System returned to ROM by reload
System image file is "flash:c1700-adventerprisek9-mz.124-15.T.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 1760 (MPC860P) processor (revision 0x500) with 123157K/7915K bytes of mem
ry.
Processor board ID FOC08490ZUQ (3780485029), with hardware revision 0000
MPC860P processor: part number 5, mask 2
1 FastEthernet interface
2 Serial(sync/async) interfaces
1 ISDN Basic Rate interface
2 Voice FXO interfaces
32K bytes of NVRAM.
49152K bytes of processor board System flash (Read/Write)
Configuration register is 0x3922
Waqas
Anas Abueideh
Level 9
Level 9
if you use it as a direct line without AA, is it working ?
check if your transcoder if it is registered or not ?
Anas
please rate if it is helpful
