2901 router and RightFax issues
David Coelho
On a remote site, I have a 2901 router working as a pass through for two T1s to a RightFax server. Tghis router is also connected to our HQ CallManager but the RightFax does not hit that. The office is complaining about intermitent issues. The guys working with them on RightFax do not think it is on their end (of course).
They are seeing errors in Right Fax reading "RLF: 'Loop-Current Drop' on line 10. Count=2 Oldest=0x5124215D."
Thanks for the help!!!!
David
Config:
Current configuration : 12032 bytes
version 15.1
service password-encryption
hostname VSMNSRST01
boot-start-marker
boot system flash:c2900-universalk9-mz.SPA.151-4.M.bin
boot-end-marker
card type t1 0 0
card type t1 0 3
logging buffered 51200 warnings
enable secret 5 $1$4p0v$.uUb64cP373QJQp0Gv4hR0
aaa session-id common
network-clock-participate wic 0
network-clock-participate wic 3
network-clock-select 1 T1 0/0/0
network-clock-select 2 T1 0/3/0
no ipv6 cef
ip source-route
ip cef
no ip domain lookup
ip domain name
isdn switch-type primary-ni
        quit
voice-card 0
codec complexity medium
dspfarm
dsp services dspfarm
voice service voip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
  h225 display-ie ccm-compatible
  call preserve
  session transport udp
  h245 tunnel disable
sip
voice class codec 1
codec preference 1 g729r8
codec preference 2 g711ulaw
voice class h323 1
  h225 timeout tcp establish 3
  call start fast
voice translation-profile Inbound
translate calling 2
translate called 1
voice translation-profile SRST
translate calling 50
fax send transmitting-subscriber $s$
license udi pid CISCO2901/K9 sn FTX1614847T
hw-module pvdm 0/0
hw-module pvdm 0/1
redundancy
controller T1 0/0/0
cablelength long 0db
pri-group timeslots 1-17,24
controller T1 0/3/0
pri-group timeslots 1-24
controller T1 0/3/1
clock source internal
interface Loopback0
no ip address
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
ip address 10.9.254.163 255.255.0.0
duplex auto
speed auto
h323-gateway voip interface
interface Serial0/3/0:23
description INTEGRA LS522321 RightFax T1
no ip address
encapsulation hdlc
isdn incoming-voice voice
no cdp enable
interface Serial0/3/1:23
description INTEGRA LS522322 RightFax T1
no ip address
encapsulation hdlc
VSMNSRST01#sh run | b :23
interface Serial0/0/0:23
description INTEGRA LS5202822 Voice T1
no ip address
encapsulation hdlc
no cdp enable
no ip address
encapsulation hdlc
no cdp enable
no ip address
encapsulation hdlc
no cdp enable
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route 0.0.0.0 0.0.0.0 10.9.254.254
ip tacacs source-interface Loopback0
access-list 23 permit 10.10.10.0 0.0.0.7
tacacs-server host 10.5.81.31
tacacs-server directed-request
tacacs-server key 7 021205580A051C32444F1B1C011C1712
control-plane
voice-port 0/0/0:23
voice-port 0/3/0:23
voice-port 0/3/1:23
mgcp profile default
sccp local GigabitEthernet0/0
sccp ccm 172.31.0.11 identifier 1 version 6.0
sccp ccm 172.31.0.10 identifier 2 version 6.0
sccp
sccp ccm group 999
associate ccm 2 priority 1
associate ccm 1 priority 2
associate profile 1 register MN_AXXIS_CFB
dspfarm profile 1 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
associate application SCCP
shutdown
dial-peer voice 71 pots
preference 1
destination-pattern 7[2-9].........
port 0/3/0:23
forward-digits 10
dial-peer voice 72 pots
preference 2
port 0/3/1:23
forward-digits 10
dial-peer voice 73 pots
preference 1
destination-pattern 71[2-9]..[2-9]......
port 0/3/0:23
forward-digits 11
dial-peer voice 74 pots
preference 2
port 0/3/1:23
forward-digits 11
dial-peer voice 61 voip
destination-pattern 0202
session target ipv4:10.9.81.22
incoming called-number .
voice-class codec 1
voice-class h323 1
dtmf-relay h245-alphanumeric
fax-relay ecm disable
ip qos dscp cs3 signaling
no vad
dial-peer voice 62 voip
destination-pattern 0210
voice-class codec 1
voice-class h323 1
no vad
dial-peer voice 63 voip
destination-pattern 024[48]
voice-class codec 1
voice-class h323 1
no vad
dial-peer voice 64 voip
destination-pattern 0269
voice-class codec 1
voice-class h323 1
no vad
dial-peer voice 65 voip
destination-pattern 040[78]
voice-class codec 1
voice-class h323 1
no vad
dial-peer voice 66 voip
destination-pattern 0293
voice-class codec 1
voice-class h323 1
no vad
dial-peer voice 67 voip
destination-pattern 0396
voice-class codec 1
voice-class h323 1
no vad
dial-peer voice 68 voip
destination-pattern 0418
voice-class codec 1
voice-class h323 1
no vad
gatekeeper
shutdown
call-manager-fallback
max-conferences 8 gain -6
transfer-system full-consult
ip source-address 10.9.254.163 port 2000
max-ephones 42
max-dn 100 dual-line
transfer-pattern .......
voicemail 913012872600
alias 1 8120 to 913012872700
translation-profile incoming SRST
call-forward busy 913012872700
call-forward noan 913012872700 timeout 16
Anas Abueideh
Level 9
Level 9
how do you integrate your router with  rightfax ? do you use SIP or H323 ?
I have bad experience with SIP. I integrate between call manager and rightfax using inter cluster (H323) and test adding rightfax to call manager as H323 gateway
Anas
please rate if it is helpful
