02-14-2012 11:56 AM - edited 03-16-2019 09:35 AM
Hai friends ,
i am using CUCM version 8.0 ,My Callmanager is integrated with our Domain controller using LDAP ,my issue i had created one user profile and i associated one Extension to this Profile .when trying to access through user profile ''X.X.X.X\ccmuser its giving error "Access to the requested resource has been denied" .
If any one knows please provide me the solution
Thanks.,
Solved! Go to Solution.
02-14-2012 12:00 PM
Make sure the user is associated with "Standard End User Group".
HTH,
Chris
02-14-2012 12:00 PM
HTH,
Chris
12-23-2020 04:55 AM
Having similar issue, while try to make any change to a LDAP user in "End User" page.
As i press the "Save" button , gets error : "Access to the Requested resource is denied" .
End user is already associated with the "Standard CCM End User" Group.
I was able to update another user of same cluster , however issue seems to be with a particular user only.
Any idea or suggestion would be helpful .
Thanks !!
11-23-2021 10:49 AM
Hello Sumeetraj
Did you resolve this issue?
I have the same problem.
