active phone on CUCM
Hi . Is there a way to check specific phone registered on CUCM  on active call or not ?  RTMT shows only registered or not but not call status for phone. I remember was working on CO system 6 yrs ago was able to see phone call status also caller and called numbers, start time with nice GUI interface .
Maybe at least trough cli on CM directly ?
Thank you
giorgiosalsiri
If you are just trying to see if a particular phone is on an active call, you can enable "Web Access" on the Phone Configuration page.  Once that is done, you can click on the IP Address of the phone, and check the "Stream Status" on the Streaming Status section.
From RTMT go to Voice/Video > Session Trace View Log > Real Time Trace.
You can filter for specific extension/number. Calls with blank termination cause are still active. Here you get all the details about the call (start time, codec, etc)
Mohammed (+5) I didnt realise that . Thanks for that
Please rate all useful posts
It is sad Cisco didn't implement such mechanism to monitor phone activity. You can't use  RTMT  for this case because with rtmt u need to know is it incoming call to that extension or outgoing, then u need to know what to monitor extension or whole DID .
