add Carrier access codes - need to send digits after call connected
pauls.savage
Hi all
hope you can help.  need advice/solution from community.
have scenario where, users dial a national number.  once call connected, requires new telephone number to be sent.
first i dial:
0811288XXXX,
After call connects, IVR prompst for dialed number to have the carrier connect call.  reqauire to automatically add:
18777XXXXXX
have tried with dial peer to prefix number and add delay, tried with Overlap -Sending from CUCM and set ISDN se 0/0/0 as isdn overlap-recieving
Any possible solutions, has anyone else done this.  if so can you please pass solution to me
thanks in advance
Jaime Valencia
What CUCM version do you have?
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Running : CUCM 8.6.2.22030-1
paolo bevilacqua
You can use my script "speed dial with pauses". It can be acquired on the website mentioned in my profile.
