add electric supplier to Cisco UCS-C200M2 server
shohamshalom
hello
i have Cisco UCS-C200M2 server with one electric supplier
i need to know if it safe to add  one more without turn off the server
i dont want any damage here
tk
shoham
anchoudh
Level 9
Level 9
Hi shoham,
Please refer the section "Installing Power Supplies " in the below link,
http://www.cisco.com/en/US/docs/unified_computing/ucs/c/hw/C200M1/install/replace.html#wp1053311
Note
If  you have ordered a server with power supply redundancy (at least two  power supplies), you do not have to power off the server to replace a  power supply because they are hot pluggable.
Hope this helps.
Anand
Please rate helpful posts !!
