01-03-2016 08:23 AM - edited 03-17-2019 05:23 AM
voice register pool-type 8800
description Cisco IP Phone 8800
phoneload-support
reference-pooltype 6921
do we need to follow same steps for 7800 model for phone load please advice.
Solved! Go to Solution.
01-03-2016 04:00 PM
Below is the recommended config
New phone model |
Recommended Fast-track config |
7821 |
voice register pool-type 7821 |
7841 |
voice register pool-type 7841 |
7861 |
voice register pool-type 7861 |
New phone model |
7821 |
7841 |
7861 |
https://communities.cisco.com/message/150437#150437
https://supportforums.cisco.com/document/12210701/fast-track-support-sip-phones
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeadm/cmebasic.html#50575
regards,
01-03-2016 04:00 PM
New phone model |
7821 |
7841 |
7861 |
New phone model |
7821 |
7841 |
7861 |
regards,
01-03-2016 08:00 PM
Thanks for the information.
Could please let me know the Recommended Fast-track config for 8800 series model also or please let me know where I can find this config.
01-03-2016 08:39 PM
for 88xx , we can use 6941 as a reference type.
Configuration example:
voice register pool-type 8831
phoneload-support
telnet-support
num-lines 6
description 8831 Phone
reference-pooltype 6941
mentioned doc consist the same: https://supportforums.cisco.com/document/12210701/fast-track-support-sip-phones
03-30-2016 08:32 AM
Dear Sir,
We have two Sites .example site A and Site B.call manager Bussiness Edition 6000 is placed in site-A and Site-B phones are registered on this BE 6000 through VPN.In Site-B there is a SRST Router for the redundancy
In site-B there is cisco 7975,7962 ,cp 6921 and cp7861 iphones
After finishing the configuration 7675 and 7962 is able to register on srst router after loss the connectivity of BE 6000.but cp 6921 and cp7861 iphones are not registering on srst router.Please help me
Find the configuration SRST Router Configuration. Please let me know if i should make changes,Because this is the first time im doing this.please help me
version 15.4
hostname AUH_SRST
ip dhcp pool VOICE
import all
network 192.168.50.128 255.255.255.128
default-router 192.168.50.130
option 150 ip 10.10.3.251 10.10.3.250
lease 30
no ip domain lookup
trunk group AUH_FXO
hunt-scheme round-robin
cts logging verbose
crypto pki trustpoint TP-self-signed-2478824890
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2478824890
revocation-check none
rsakeypair TP-self-signed-2478824890
crypto pki certificate chain TP-self-signed-2478824890
certificate self-signed 01
voice-card 0
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
registrar server expires max 600 min 60
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
voice iec syslog
voice register global
mode srst
voice translation-rule 1
rule 1 /[0-9]+/ /9&/
rule 2 /971/ /900971&/
voice translation-profile FROM_ISP
translate calling 1
application
global
service alternate default
license udi pid CISCO2921/K9 sn FCZ193661MR
hw-module pvdm 0/0
username admin privilege 15 password 0 admin
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0.10
description #MANAGEMENT#
encapsulation dot1Q 10
ip address 192.168.22.5 255.255.255.248
interface GigabitEthernet0/0.60
description #vOICE vLAN#
encapsulation dot1Q 60
ip address 192.168.50.130 255.255.255.128
h323-gateway voip interface
h323-gateway voip bind srcaddr 192.168.50.130
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.50.129
logging trap debugging
control-plane
voice-port 0/0/0
trunk-group AUH_FXO
translation-profile incoming FROM_ISP
cptone AE
timeouts call-disconnect 5
timeouts wait-release 5
timing guard-out 1000
connection plar opx 5333
caller-id enable
voice-port 0/0/1
trunk-group AUH_FXO
cptone AE
caller-id enable
voice-port 0/0/2
trunk-group AUH_FXO
cptone AE
caller-id enable
voice-port 0/0/3
trunk-group AUH_FXO
cptone AE
caller-id enable
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
dial-peer voice 1 pots
incoming called-number .
dial-peer voice 1000 voip
destination-pattern 5333
session target ipv4:10.10.3.250
voice-class codec 1
dial-peer voice 1001 voip
destination-pattern 53..
voice-class codec 1
sip-ua
gatekeeper
shutdown
call-manager-fallback
secondary-dialtone 9
max-conferences 8 gain -6
transfer-system full-consult
timeouts interdigit 5
ip source-address 192.168.50.130 port 2000
max-ephones 25
max-dn 50 dual-line
system message primary MELCO_LOCAL
system message secondary MELCO_LOCAL
transfer-pattern .T
keepalive 20
call-forward pattern .T
call-forward busy 5333
call-forward noan 5333 timeout 45
time-zone 35
date-format dd-mm-yy
