Add Prefix for international Calling numbers
ggl277808
Hi there,
I´ve migrated a CUCM 6 to CUCM10.5, so the Gateways remain with the same configuration and all work fine, except ip phones does not display the prefix number for incoming international calls.
Any ideas??
Thanks in advance.
Guillermo
Hello Guillermo,
Kindly mark it as answered.
Thank you,
Sahdi
24 Replies 24
Shadi Shami
Level 7
Level 7
Hello Guillermo,
Can you add more details please? How the GW is connected to CUCM, is MGCP, SIP or H323?
How are you connected to PSTN, SIP Trunk, PRI (E1/T1) or FXO?
Thank you,
Shadi
Hi Shadi,
I´ve 3  gateways in different location, connected via H323 to CUCM, and the gateways are connected via PRI(E1)interfaces.
Thank you
Guillermo
Can you please navigate to Device > Gateway, open one of the GWs and scroll down into: Incoming Calling Party Settings > International Number, and check whether the prefix showing up there or not?
If there, please collect the following debugs from one of the GWs:
debug isdn q931
debug voip ccapi inout
and provide running config.
Thank you,
Shadi
Here is the running config and I´ve attached the screenshot of the calling party setting of a gateway and the logging file.
Thank you Shadi
no ip domain lookup
no ftp-server write-enable
isdn switch-type primary-net5
voice rtp send-recv
voice service voip
voice class codec 1
 codec preference 1 g711ulaw
 codec preference 2 g729r8
 codec preference 3 g711alaw
voice class h323 1
 h225 timeout tcp establish 3
controller E1 0/0
 pri-group timeslots 1-31
translation-rule 1
 Rule 0 ^700. 91374040
 Rule 1 ^701. 91374041
 Rule 2 ^702. 91374042
 Rule 3 ^704. 91337704
 Rule 4 ^705. 91337705
voice-port 0/0:15
 no vad
 cptone ES
dial-peer cor custom
dial-peer voice 9000 pots
 description llamadas nacionales
 destination-pattern 0[89]........$
 progress_ind setup enable 3
 progress_ind alert enable 8
 fax rate disable
 direct-inward-dial
 port 0/0:15
 forward-digits 9
dial-peer voice 6000 pots
 description llamadas moviles
destination-pattern 0[67]........$
 fax rate disable
 direct-inward-dial
 port 0/0:15
 forward-digits 9
dial-peer voice 9900 pots
 description llamadas internacionales
 destination-pattern 000T
 fax rate disable
direct-inward-dial
 port 0/0:15
 prefix 00
dial-peer voice 112 pots
 description llamada emergencia
 destination-pattern 01..
 direct-inward-dial
 port 0/0:15
 prefix 1
dial-peer voice 91 pots
 destination-pattern 010..
 direct-inward-dial
 port 0/0:15
 forward-digits 4
 prefix 1
dial-peer voice 118 pots
 description llamadas informacion
 destination-pattern 0118..
 direct-inward-dial
 port 0/0:15
 prefix 118
dial-peer voice 95302 voip
 description llamadas entrantes
 huntstop
 destination-pattern 9530207..
no modem passthrough
 voice-class codec 1
 voice-class h323 1
 session target ipv4:192.168.65.11
 dtmf-relay h245-alphanumeric
 fax-relay ecm disable
 fax rate 9600
 fax protocol pass-through g711alaw
dial-peer voice 8100 voip
 description Tfnos SRST Registrados en Cisco1760
 preference 10
 destination-pattern 81..
 voice-class h323 1
 session target ipv4:192.168.65.2
 codec g711alaw
 fax rate 9600
dial-peer voice 1400 pots
 description llamada telefonica
 destination-pattern 014..
 direct-inward-dial
 port 0/0:15
 prefix 14
dial-peer voice 95359 voip
 destination-pattern 9535981..
 modem passthrough nse codec g711alaw
 voice-class codec 1
 voice-class h323 1
 incoming called-number .
 fax rate disable
dial-peer voice 8167 voip
 description fax
 destination-pattern 953598167
 codec g711alaw
 fax rate disable
dial-peer voice 8168 voip
 description fax
 destination-pattern 953598168
 codec g711alaw
 fax rate disable
dial-peer voice 953 voip
 description llamadas entrantes SRST
 preference 10
 voice-class codec 1
dial-peer voice 8000 pots
 description llamadas 807117000
 destination-pattern 0807......
 fax rate disable
 direct-inward-dial
 port 0/0:15
 prefix 807117000
dial-peer voice 5 pots
 description llamadas Salesforce Internacionales
 destination-pattern 500T
 direct-inward-dial
 port 0/0:15
 prefix 00
dial-peer voice 56 pots
 description llamadas Salesforce Moviles
 destination-pattern 56........
 direct-inward-dial
 port 0/0:15
 prefix 6
dial-peer voice 59 pots
 description llamadas Salesforce Nacionales
 destination-pattern 59........
 direct-inward-dial
 port 0/0:15
 prefix 9
dial-peer voice 8001 pots
 destination-pattern 807......
 fax rate disable
 direct-inward-dial
 port 0/0:15
 prefix 807
dial-peer voice 2112 pots
 destination-pattern 21[12]6........
 fax rate disable
 direct-inward-dial
 port 0/0:15
 prefix 6
dial-peer voice 2123456789 pots
 destination-pattern 2[123456789]06........
 fax rate disable
 direct-inward-dial
 port 0/0:15
 forward-digits 9
dial-peer voice 26 pots
 destination-pattern 6........
 fax rate disable
 direct-inward-dial
 port 0/0:15
 prefix 6
no dial-peer outbound status-check pots
call-manager-fallback
 max-conferences 4 gain -6
 fax rate disable
 direct-inward-dial
 port 0/0:15
 prefix 6
Hello Guillermo,
I couldn't find any prefix configured on CUCM for H323 GW, as well not such config on the Gateway (router) itself.
From the debugs, I found an international call (calling number is: 21321928443). kindly add the prefix you want under the GW configuration on CUCM: International Number > replace "Default" with the prefix that you want then save and reset.
Thank you,
Shadi
Here is another running config from another gateway and a log file attached .
So, I receive calls from many countries, Italy, France, EEUU, Germany, etc.. Have I to add the prefix for all this countries? Or is there another way to do that?
Sorry by my ignorance,
Thank you
Checked them, and same as before calling numbers for international calls come without 00 (or +).
can you advice what prefix you want to add?
all international calls will have the same prefix? If yes, what is that prefix?
The prefix that I want the IP Phone display its the country code + phone number, I only can see the phone number, right now:
These are some of the country codes where I usually receive phone calls.
Thank you.
+61 Australia
+20 Egypt
+49 Germany
+33 France
+39 Italy
+1 EEUU
+44 UK
from the provided debugs I noticed that numbers were sent but without (+), which you can add in the GW configuration page on CUCM under  Calling Party Settings > International Number, remove "default" and add + , then save the changes and click on the reset button.
I´ve made the change that you recommend me, but it does not work.
for example the entire number is:
00393484820XXX
and in the display phone appears:
        0484820XXX
The prefix number [0039] does not appears, and the first number "3" is substitute by "0"
Thank you
on the ip phone that received the call, can you check the directory (either received calls/ missed calls). how the number is showing up there?
I´ve sent you the number that appear in the ip phone receive/missed calls directory
under Service parameters, enable digitanalysis complexity and collect CCM logs covering a test calls. or if you prefer we can have a remote session to check the issue.
Hello Shadi,
Yesterday under Service parameters, I check the option TranslationAndAlternatePatternAnalysis, and I was doing some tests under dna in call manager, but I couldn´t see the problem either.
We could do the remote session if you want.
Thank a lot for your help.
Guillermo
