Add Prefix for international Calling numbers
ggl277808
Hi there,
I´ve migrated a CUCM 6 to CUCM10.5, so the Gateways remain with the same configuration and all work fine, except ip phones does not display the prefix number for incoming international calls.
Any ideas??
Thanks in advance.
Guillermo
24 Replies 24
Hello Guillermo,
If you are available now, send me a message with your temaviewer ID/ password.
Thank you,
Shadi
Hi Shadi,
The teamviewer ID: 421 429 401
and Password: 7039
Thank you.
<< Joined Guillermo a remote session and reviewed the call routing, then we were able to resolve the problem by adding prefix to International numbers under the H323 configuration page in CUCM>>
Hello Guillermo,
Kindly mark it as answered.
Thank you,
Sahdi
Hello Shadi,
I hope this message find you well.
I´ve the same problem with the ip phones inside the company. As you must remember we have tested the incoming call against ip communicator, but, against one ip phone 7940 series for example, the calling number is cut.
I´ve configured the same DN in me Ip communicator and I could see it.
I´ve compared both DN and Phone CSS and options configured, and all seems to be ok, but it doesn´t work.
If you have any idea, or if you want, we could have another remote session, then you´ll see in details the problem.
Thank you in advance
Guillermo
Hello Guillermo,
Everything is OK, thank you my friend :)
We can do it tomorrow 11:00 am CET (GMT+2)
Thank you,
Shadi
Ok Shadi,
I´ll be waiting.
Thank you.
Hello Guillermo,
CAn you please share teamviewer credential?
Thank you,
Shadi
Hi Shadi
ID 421 429 401
Psswd 5353
Issue resolved, check the thread below for more info:
https://supportforums.cisco.com/discussion/12479966/cucm-cutting-incoming-international-calls-numbers
