Adding 7915 expansion module into CUCM Business Edition 6.1.1
Aaziz AMHAOUCH
Hi all,
We have a problem in adding 7915 expansion module into CUCM Business Edition version 6.1.1.2000, we didn't find this device type in "Device Defaults Information". Do I need to install a CUCM device package to resolve this issue ? if so, is there a device pack for CUCM Business Edition or I need just a CUCM device pack ?
Thank you in advance,
Best regards
Aman Soi
Hi Aziz,
I think you are using Call Manager version 6.1.1.2000-3  which is 6.1(1a).If I check the software compatibility guide,it shows the SCCP firmware version cmterm-7915-sccp.1-0-2.cop.sgn under 6.1(1b) which is 6.1.1.3000-2.
Secondly, in 7915 datasheet I also do not support for Call Manager Business Edition.It is bit confusing.
Call-control compatibility
Cisco Unified Communications Manager 4.2(3) SR3a, 4.3(2), 5.1(3)b, 6.1(1), 7.0, 7.1 and later; Cisco Unified Communications Manager Express 4.3/7.0 and later. Cisco Unified Survivable Remote Site Telephony (Unified SRST) 4.1 (IOS 12.4.15T) and later.
Can u first try downloading the patch for 6.1(1b) first and check whether 7915 is coming in call manager or not ?
regds,
aman
Thank you Aman,
We resolved this issue by installing a CUCM Device Pack 6.1. then we placed the firmware name on " Module 1 Load Name"  field and it works !
Best regards,
Hi Aziz,
Good your problem has been solved.
Can u just let us know the name of Device Pack which u have installed and share the output of command show version active from Publisher ?
regds,
aman
