Adding DID's to CallManager
Randy Haddon
hello,
 I am needing to add a new block of DID's to our call manager 9.1.2.  I have added the dial-peer into the router with no problems, but when I went to add the numbers into the call manager under Call Routing and opened up Directory Number I put the first series of DID's in,  I then assinged on of the new DID's to a phone and when I tried to call it the recording come on this number is no longer in service (rang 2 times before the recording started).  not sure what part I am missing, any help would be appreciated.
note: the block of DID's are not sequential.
Randy
8 Replies 8
Jaime Valencia
This is the Video Over IP forum, might want to move this to IP Telephony
java
if this helps, please rate
Sorry about that mis-read the group name.
Randy
Is the call even hitting your GW?
Are you sure the telco has properly enabled the new DIDs?
java
sorry for the delay in getting back with you Jamie, no the calls are not hitting the gateway but I am able to call out from a phone with the new extension and I can dial it internally.
I used debug voip dialpeer detail to see if the call was hitting the GW.  I also used the RTMT and saw the call going out from the new extension but nothing on the call coming in.
Randy
If the call is not hitting your GW, you need to call your telco
java
Jamie sorry for the delay in getting back with you, I ran another debug and here are the results from it.
010881: Apr 5 16:00:22.838: ISDN Se0/1/0:23 Q931: TX -> SETUP pd = 8 callref = 0x4EF8
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98391
Exclusive, Channel 17
Calling Party Number i = 0x0081, '9182875499'
Plan:Unknown, Type:Unknown
Called Party Number i = 0xA1, '9182870005'
Plan:ISDN, Type:National
010882: Apr 5 16:00:22.950: ISDN Se0/1/0:23 Q931: RX <- CALL_PROC pd = 8 callref = 0xCEF8
010883: Apr 5 16:00:22.954: ISDN Se0/1/0:23 Q931: RX <- PROGRESS pd = 8 callref = 0xCEF8
Cause i = 0x80FF - Interworking error; unspecified
Progress Ind i = 0x8088 - In-band info or appropriate now available
010884: Apr 5 16:00:25.698: ISDN Se0/1/0:23 Q931: RX <- PROGRESS pd = 8 callref = 0xCEF8
Progress Ind i = 0x8081 - Call not end-to-end ISDN, may have in-band info
010885: Apr 5 16:00:27.870: ISDN Se0/1/0:23 Q931: TX -> DISCONNECT pd = 8 callref = 0x4EF4
Cause i = 0x8090 - Normal call clearing
010886: Apr 5 16:00:28.146: ISDN Se0/1/0:23 Q931: RX <- RELEASE pd = 8 callref = 0xCEF4
010887: Apr 5 16:00:28.166: ISDN Se0/1/0:23 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x4EF4
010888: Apr 5 16:00:32.530: ISDN Se0/1/0:23 Q931: TX -> DISCONNECT pd = 8 callref = 0x4EF8
010889: Apr 5 16:00:32.598: ISDN Se0/1/0:23 Q931: RX <- RELEASE pd = 8 callref = 0xCEF8
010890: Apr 5 16:00:32.618: ISDN Se0/1/0:23 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x4EF8
Randy Haddon
Ratheesh Kumar
check the gateways for incoming call logs. Also check the Calling search space in the trunk. This should have access to the Phone DN partition
I did check to the call logs on RTMT and could see the call that I made from the phone with the new number but not the call coming into it.
Randy
