Adding IP Phone 8811 to System version: 10.0.1.10000-24
William Foster
I am needing to add a device pack for a 8811 phone. The version of CUCM I have is System version: 10.0.1.10000-24.  Do I really have to upgrade to 10.5.2 in order to have this phone?   I have a call manager that is 9.1 that has the option for this phone.  Why would that older version have that phone and this newer version I have not have it? Or am I just reading into this wrong? I cant seem to find a device pack for this phone for the version of CUCM I have. I am just hoping someone knows of another way to do this without having to upgrade.
Jaime Valencia
No, you HAVE to upgrade, as to why an "old" release has a DevPack and yours doesn't, read here
http://docwiki.cisco.com/wiki/CUCM_Upgrades_and_Migrations_FAQ#What_is_a_CUCM_MR_.28maintenance_release.29.3F.3F
java
if this helps, please rate
You  are reading it right, we need to upgrade cucm to 10.5 as in version 10.1 the supported 88xx models were 8841,8851,8861.
http://www.cisco.com/web/software/282074299/113727/cmterm-devicepack10.0_1_12007-1_Release_Notes.pdf
You can have a look on the below bug which would answer your second query.
https://tools.cisco.com/bugsearch/bug/CSCuv62220
http://www.cisco.com/web/software/282074299/130788/cmterm-devicepack10.5.2_13050-1_Release_Notes.pdf
Aman Soi
Hi William,
you need to upgrade CUCM to 10.5.2 as per the datasheet it is supported on 10.5.2.
Adding Device pack to CUCM 10.0.1.10000-24 is not going to help.
Cisco Unified Communications Manager
  8.5.1 (Non-secured mode Only)
  8.6.2
  9.1.2
  10.5.2
  11.0 and later
regds,
aman
Find this matrix helpful
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/compat/matrix/CMDP_BK_CCBDA741_00_cucm-device-package-compatibility-matrix/CMDP_BK_CCBDA741_00_cucm-device-package-compatibility-matrix_chapter_00.html
Abhay
Abhay Singh Reyal
The Only Way To Do Great Work Is To Love What You Do. If You Haven’t Found It Yet, Keep Looking. Don’t Settle
