Adding new IP Phones to CME 8.6
rhyan.sanandres
I have 2921 running with CME 8.6. Now, I need to add new IP phones. Ive purchased CM license for each Phones plus Feature License for Communication Express with bundled 25 (FL-CCME-25). My question is, do I need this FL licenses to Work? Will this be installed in the router? What impact if I will not purchase this Feature License and RTU phone Licenses?
Thnks!
5 Replies 5
Chris Deren
CME licenses are paper RTU licenses that do not get applied to the system.
Chris
Hi Chris,
Thank you for the reply. Is it really needed? What if I will not purchase it? What will happen or impact to the system?
Ok Chris! Thanks a lot for the help.
Chris Deren
Then you would be breaking licensing agreement and be running the software illegally.
Chris
Thanks Chris!!
