Adding phone models to CUCME
Chris Campbell
I am trying to learn CUCME.  I have a 2951 router and 7821 phones.
When I go into telephony-service and do a load, I don't see the 7821 in the list.  I have the 7821 software files that I downloaded from Cisco.  I can't figure out what needs to be updated or changed so I get the option to specify a 7821.  Can someone help?
#show telephony-service
CONFIG (Version=12.0)
Version 12.0
Max phoneload sccp version 17
Max dspfarm sccp version 18
(config-telephony)#load ?
  12SP       12SP+ and 30VIP phones
  6901       Cisco IP Phone 6901
  6911       Cisco IP Phone 6911
  6921       Cisco IP Phone 6921
  6941       Cisco IP Phone 6941
  6945       Cisco IP Phone 6945
  6961       Cisco IP Phone 6961
  7902       Cisco IP Phone 7902
  7905       Cisco IP Phone 7905
  7906       Cisco IP Phone 7906
  7910       Cisco IP Phone 7910
  7911       Cisco IP Phone 7911
  7912       Cisco IP Phone 7912
  7914       Cisco IP Phone 7914 14-Button Line Expansion Module
  7915-12    Cisco IP Phone 7915 12-Button Line Expansion Module
  7915-24    Cisco IP Phone 7915 24-Button Line Expansion Module
  7916-12    Cisco IP Phone 7916 12-Button Line Expansion Module
  7916-24    Cisco IP Phone 7916 24-Button Line Expansion Module
  7920       Cisco IP Phone 7920
  7921       Cisco IP Phone 7921
  7925       Cisco IP Phone 7925
  7926       Cisco IP Phone 7926
  7931       Cisco IP Phone 7931
  7935       Cisco IP Conference Station 7935
  7936       Cisco IP Phone 7936
  7937       Cisco IP Conference Station 7937
  7941       Cisco IP Phone 7941
  7941GE     Cisco IP Phone 7941GE
  7942       Cisco IP Phone 7942
  7945       Cisco IP Phone 7945
  7960-7940  Cisco IP Phone 7940/7960
  7961       Cisco IP Phone 7961
  7961GE     Cisco IP Phone 7961GE
  7962       Cisco IP Phone 7962
  7965       Cisco IP Phone 7965
  7970       Cisco IP Phone 7970
  7971       Cisco IP Phone 7971
  7975       Cisco IP Phone 7975
  7985       Cisco IP Phone 7985
  8941       Cisco IP Phone 8941
  8945       Cisco IP Phone 8945
  ata        ATA  phone emulation for analog phone
Chris Deren
78XX and 88XX phones are SIP only and cannot be added under telephony-service which is SCCP only.  You need to add SIP phones under "voice register global" and add the devices as "voice register pool ".  Check out CME Admin guide for detailed directions. In addition CME allows you to add phone models not supported by your CME version without upgrading the IOS by utilizing "Fast-track" feature, but since support of 78XX models was added in version 11.7 you should not need it.
Jaime Valencia
The only way to add support for new phone models is to upgrade your CME version to one that natively supports it, or try to use fast track if applicable to your phone model.
java
if this helps, please rate
Chris Deren
This is correct.  I was looking at an old configuration example and trying to work through that.  I knew I was using a SIP phone, but didn't realize that SIP phones use a different configuration command.  Thanks for the response.
