Adding Station IDs and number masks to calls being passed through
ERRIN MILLER
I have a PBX connected to CallManager.  If it possible for me to add a "Calling Name"?  If a call originates from 3337901 I want the station name to say East Desk.  Any way to do that?
Also, can we add a mask, so that when someone calls outbound it changes it, like you can on a DN?
Gateways are PRI, MGCP.  UCM 8.  Thanks.
Jaime Valencia
You need to configure the alerting name and the display internal caller ID on the DN for the info to be used.
Modifying the ANI you send can be configured in a number of ways and levels. calling party transformation patterns, route pattern, route list, GW, set the external phone number mask in DN.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
