Administrators login session Resrictions
Hi All,
how can i restrect admin login session from Call Manager to be only one session ?
also how can i define the management stations in call manager ? like from which PC ccm should accept connections ?
thank you in Advance
Jaime Valencia
No way to do any of what you want in CUCM, the second one, you might use ACLs in an ISR depending on your network config.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
