04-13-2013 05:38 AM - edited 03-16-2019 04:46 PM
Hi all...
I have a cucm 7.1 & 2901 router which act as a gatekepeer ,also a gateway.. Two analog phone are connected on gatway... i am sucessfully connect two gateway on gatekepeer. Gatekepper endpoint show two zones.. But when i give call from CUCM to analog phone after one beep connection going disconnect..... can any one give me any idea..... Please check the attachment file where 7799 from CUCM no & 5555 for analog phone number...
Solved! Go to Solution.
04-13-2013 08:03 AM
Hello
please answer the questions
why you use the intercluster controlled?. You have to use gatekeeper controlled.
Why you use significant digits all ?. you have to use it to 4 .
please tell me the scinario which you need to complete from where to where?.
Thank you
please rate if this will help
04-13-2013 08:24 AM
Hello
In a distributed call-processing network with gatekeepers, use an intercluster trunk with gatekeeper control to configure connections between clusters of Cisco Unified Communications Manager systems. Gatekeepers provide call admission control and address resolution for intercluster calls. A single intercluster trunk can communicate with all remote clusters. To choose this method, use Device > Trunk and choose Inter-Cluster Trunk (Gatekeeper Controlled) in Cisco Unified Communications Manager Administration.
You also configure route patterns and route groups to route the calls to and from the gatekeeper. In this configuration, the gatekeeper dynamically determines the appropriate IP address for the destination of each call, and the local Cisco Unified Communications Manager uses that IP address to complete the call
Thank you
04-13-2013 08:33 AM
Hello
Any way ,did you configure a route pattern for 5... and this RP uses RL which includes your configured trunk?.
thank you
04-15-2013 05:01 AM
hello
Thank yu for your reply , i am still confused . But if you will need to do a call for 7799 which is a dn on your CUCM. You must match this on your gatekeeper
zone prefix zonec 7...
or if you have many numbers (start with 4 or 7)
zone prefix zonec [4-7]...
Thank you
04-13-2013 07:01 AM
Hello
can you share the configuration on your CUCM , gatekeeper and your gateway please. I think a problem of mismatching codecs. P
thank you please rate if this will help
04-13-2013 07:40 AM
Thanks kamal. My zonea & zoneb can communicate each other but my zonec which is CUCM can not communicate with zonea & zonec.after one ring call disconnect..
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2013.04.13 20:03:45 =~=~=~=~=~=~=~=~=~=~=~=
interface GigabitEthernet0/0
ip address 10.10.10.122 255.255.255.0
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip id zonea ipaddr 10.10.10.122 1719
h323-gateway voip h323-id zonea
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 10.10.10.254
control-plane
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
mgcp profile default
dial-peer voice 5555 voip
destination-pattern ....
session target ras
dial-peer voice 1 pots
destination-pattern 5555
--More-- port 0/0/0
gateway
timer receive-rtp 1200
gatekeeper
zone local zonea ewmgl.com.bd 10.10.10.122
zone local zoneb ewmgl.com.bd
zone local zonec ewmgl.com.bd
zone prefix zonec 4...
zone prefix zonea 5...
zone prefix zoneb 6...
no shutdown
ZONE-A#sh agt gateke
ZONE-A#sh gatekeeper en
ZONE-A#sh gatekeeper endpoints
GATEKEEPER ENDPOINT REGISTRATION
CallSignalAddr Port RASSignalAddr Port Zone Name Type Flags
10.10.100.1 35497 10.10.100.1 44168 zonec VOIP-GW
H323-ID: GATEKEEPER_1
Voice Capacity Max.= Avail.= Current.= 0
10.10.10.122 1720 10.10.10.122 53772 zonea VOIP-GW
E164-ID: 5555
H323-ID: zonea
10.10.81.251 1720 10.10.81.251 61517 zoneb VOIP-GW
E164-ID: 6666
H323-ID: zoneb
Total number of active registrations = 3
04-13-2013 08:03 AM
Hello
Thank you
04-13-2013 08:06 AM
Hello
i can not understand your design, You can use only one zone and through these zone you can admin the calls between gateways and CUCM
thank you
04-13-2013 08:24 AM
Hello
Thank you
04-13-2013 08:33 AM
Hello
thank you
04-13-2013 08:36 AM
Thanks kamal............. after changing intercluster to ...
gatekeeper controlled problem is solved...... thanks........................ a lot
04-13-2013 08:38 AM
Hello
very welcome my friend . I am so pleased that you solve your problem. Any help any time.
Thank you
islam kamal
04-14-2013 10:21 PM
Thanks kamal.... CUCM 7.1 can not recive incomming call.... can you give me some idea........ zonea can call zoneb , cucm also can call zonea & zoneb. where is CUCM is zonec... I check my incomming CSS which is ok... ...
04-15-2013 02:58 AM
sorry for delay ,
1-can you tell me the toplogy and can you tell me also share (debug isdn q931) for incoming call.
2-The call from 5... to 4... , is this true . Please clarrify on the trunk configuration
3-DN significant :4 ,
4-Tell me also about CSS BG-CSS-Incoming.What about tech-prefix =1719 , i did not see in your confgiuration. Please clarrify.
thank you
04-15-2013 03:17 AM
Thanks for reply..
1) As per my understanding inbound signaficiant number means how many digits come from outside rigt thats why i put all insest of 4 . .
2) BG-CSS-Incoming is .... group where my endpoint phone is registered.. using this incomming -css i already check the incomming call .with my another gateway .
duplex auto
speed auto
no ip http server
control-plane
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
session target ras
--More-- port 0/0/0
gateway
gatekeeper
no shutdown
ZONE-A#
ZONE-A#
ZONE-A#
ZONE-A#
ZONE-A#
E164-ID: 5555
H323-ID: zonea
E164-ID: 6666
H323-ID: zoneb
04-15-2013 05:01 AM
hello
Thank you
04-15-2013 05:05 AM
You are right its already done.... zonea & zoneb cannot call zonec which is CUCM 7.1 ......
04-15-2013 05:08 AM
which area are you confuged....
