AIM-CUE Upgrade Error
Bar1s
Hi Guys,
I am having a problem while try to upgrade my aim-cue module version 3.2.4.0 to version 7.0.3.
Thats my logs at down below. I couldn't any proper answer for that. This is for my lab.
Help guys.
mycue> $tall clean url ftp://192.168.1.100/cue-vm-k9.nm-aim.7.0.3.pkg
WARNING:: This command will install the necessary software to
WARNING:: complete a clean install.  It is recommended that a backup be done
WARNING:: before installing software.
Would you like to continue? [n]y
Downloading ftp cue-vm-k9.nm-aim.7.0.3.pkg
Bytes downloaded :  182241
Validating package signature ... done
Validating installed manifests ........
Foundation verification failed
Manifest signature validation failed for bootloader_sec_manifest.sig
mycue>
Aman Soi
Did u verify the MD5 checksum after u downloaded the package ?
it should be 83c78328efcf686968032333b1d922f3
regds,
aman
Hi Aman,
Also I tried with other versions. Even though I tried with files that use to upgrade my customer's aim-cue module.
I don't think that it is related with files.
Baris.
