Alcatel > Asterisk Call Transfer MOH
campbell-john
Hi Everyone,
Alcatel ---> 2901 (3xxx) <-----------------Fibre IP   LINK---------------> 2901 (in Data Centre) ------->Primary IP PBX
The above is a basic network diagram.
I have been working on linking an Asterisk based system to an Alcatel 4400 for over a year now which has gave me nothing but problems that have all been Cisco related.
I have ironed them all out apart from 1 and I am completly stumped - I would really appreciate some help.
Scanario:
Alcatel handset rings an IP handset - Call established.  Alcatel handset wants to transfer call to another Alcatel handset so they enter number.  At this point the Asterisk MOH kicks in and plays to the IP handset.  Alcatel handset puts call through and hangs up but MOH does not stop on IP handset however there is one way audio.  The Alcatel handset can hear the IP handset but the IP handset is still listning to MOH.
I found that I can fix this by setting session protocol sipv2 against the dialplan but it stops calling/called names passing up the trunk.  I would like to leave it set to session protocol cisco which allows all names/calling names etc to pass.
Config files:
Alcatel Router:
version 15.0
service password-encryption
hostname C2901_A_ALCATEL
boot-start-marker
boot-end-marker
card type e1 0 1
logging buffered 51200 warnings
no aaa new-model
network-clock-participate wic 1
network-clock-select 1 E1 0/1/0
no ipv6 cef
ip source-route
ip cef
no ip domain lookup
--More--
Oct 19 09:53:48.476: %SYS-5-CONFIG_I: Configured from console by itadmin on vty0 (10.11.0.50)
isdn switch-type primary-qsig
isdn gateway-max-interworking
voice-card 0
voice call send-alert
voice call convert-discpi-to-prog
voice call carrier capacity active
voice rtp send-recv
voice service voip
qsig decode
fax protocol pass-through g711alaw
h323
  h225 timeout setup 2
  h225 display-ie ccm-compatible
voice class codec 1
codec preference 1 g711alaw
license udi pid CISCO2901/K9 sn FCZ160990PE
hw-module pvdm 0/0
redundancy
controller E1 0/1/0
pri-group timeslots 1-31
controller E1 0/1/1
interface GigabitEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
ip address 10.0.0.52 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
ip address 10.11.0.55 255.255.255.0
duplex auto
speed auto
interface Serial0/1/0:15
no ip address
encapsulation hdlc
no logging event link-status
isdn timer T203 30000
isdn timer T310 60000
isdn overlap-receiving T302 2000
isdn incoming-voice voice
isdn send-alerting
isdn bchan-number-order ascending
isdn sending-complete
isdn outgoing display-ie
no cdp enable
router rip
network 10.0.0.0
no ip forward-protocol nd
no ip http server
no ip http secure-server
dialer-list 1 protocol ip permit
no cdp run
control-plane
voice-port 0/1/0:15
dial-peer voice 1 voip
destination-pattern 3...
session target ipv4:10.0.0.53
session transport udp
voice-class codec 1
fax-relay ecm disable
dial-peer voice 5 pots
destination-pattern 9.+
direct-inward-dial
port 0/1/0:15
prefix 9
dial-peer voice 6 voip
destination-pattern 2...
voice-class codec 1
dial-peer voice 7 pots
destination-pattern 4...
direct-inward-dial
port 0/1/0:15
prefix 4
dial-peer voice 8 pots
destination-pattern 5...
direct-inward-dial
port 0/1/0:15
prefix 5
dial-peer voice 9 pots
destination-pattern 7...
direct-inward-dial
port 0/1/0:15
prefix 7
dial-peer voice 2 voip
preference 1
session target ipv4:10.11.0.51
voice-class codec 1
sip-ua
retry invite 2
timers trying 150
gatekeeper
shutdown
line con 0
logging synchronous
login
line aux 0
line vty 0 4
exec-timeout 0 0
privilege level 15
logging synchronous
login local
transport input telnet ssh
scheduler allocate 20000 1000
end
VOIP Router
version 15.0
hostname 2901_B_DC
boot-start-marker
boot-end-marker
card type e1 0 1
no aaa new-model
no ipv6 cef
ip source-route
ip cef
no ip domain lookup
voice-card 0
voice rtp send-recv
voice service voip
qsig decode
h323
voice class codec 1
license udi pid CISCO2901/K9 sn FCZ160990PL
hw-module pvdm 0/0
redundancy
controller E1 0/1/0
controller E1 0/1/1
ip address 10.0.0.53 255.255.255.0
duplex auto
speed auto
ip address 10.11.0.54 255.255.255.0
duplex auto
speed auto
no ip address
encapsulation hdlc
isdn protocol-emulate network
isdn send-alerting
no cdp enable
no ip http server
no cdp run
control-plane
voice-port 0/1/0:15
dial-peer voice 3 pots
direct-inward-dial
port 0/1/0:15
prefix 3
dial-peer voice 9 voip
session target ipv4:10.0.0.52
voice-class codec 1
dial-peer voice 4 voip
--More--
Oct 19 09:54:28.680: %SYS-5-CONFIG_I: Configured from console by itadmin on vty0 (1 session transport udp
voice-class codec 1
dial-peer voice 7 voip
voice-class codec 1
dial-peer voice 5 voip
voice-class codec 1
dial-peer voice 2 pots
direct-inward-dial
port 0/1/0:15
prefix 2
dial-peer voice 8 voip
preference 1
session target ipv4:10.11.0.50
voice-class codec 1
dial-peer voice 10 voip
preference 1
voice-class codec 1
dial-peer voice 11 voip
preference 1
voice-class codec 1
dial-peer voice 12 voip
preference 1
voice-class codec 1
sip-ua
retry invite 2
timers trying 150
gatekeeper
shutdown
line con 0
login local
line aux 0
line vty 0 4
exec-timeout 0 0
privilege level 15
login local
end
campbell-john
anyone?
