Alcatel Phones adding to cisco Call Manager
Sunish Nair
I would like to know that is that is it possible we can add Alcatel Phones to Cisco Unified Call Manager. Please let me know if anybody knows about this.
Alcatel 4059 IP PC based   Operator Console
Alcatel 4068 IP Touch   Telephone Set
Alcatel 4038 IP Touch   Telephone Set
Alcatel 4018 IP Touch   Telephone Set
Alcatel 4008 IP Touch   Telephone Set
Alcatel 610 Mobile IP Touch   Telephone Set
5 Replies 5
Jaime Valencia
Assuming they're SIP phones you would need to follow the generic SIP 3rd party endpoint instructions to register them.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Alexey Platov
Alcatel 4059 IP PC based   Operator Console - it is attendant console. You can't use it, because it uses specific protocol with PABX.
All other 40x8 phones - depends on their HW edition. If it contains EE at the end then you cal load a SIP binary on them and use as a basic SIP set with CUCM.
Alcatel 610 Mobile IP Touch - Wi-Fi set, if i remember right Spectralink OEM. It uses specific binary so i am not sure whether you can you use without FW reload.
Ahmed Sabanaa
Hi Mr.Sunish Nair,
could you please update me if you found any solutions for your case , since i have the same case .
Ahmed Sabanaa,
Could you help me to know if you found a solution for the integration.
Hi Rogelio,
The only option here is if these phones support SIP then these can be added as third party SIP phone on cucm.
Manish
